Do you do a warm up & warm down of your moho engine ? (28 Viewers)
Mar 23, 2012
10,172
34,738
sleights
c class
But if it lasts 12 months the manufacturer is happy They only have to comply with emissions requirements .If it fails that is the owners problem at at his cost
Our car is 8 years old it's been on all the time no problem. Maybe it's been designed to work that way! It does mean when we lived in a city we at least didn't pollute stopped at the traffic lights
Aug 24, 2023
45
84
Brixham, UK
Laika Kreos 3007
September 2023 :)
A diesel should be driven as soon as it's started, it will warm up quicker under load.
Idling for a few seconds after a fast run will do no good whatsoever.....it will still be too hot to touch 10 minutes after stopping.
Next it will be said you have to run in a new van at a reduced speed .....utter crap.
A new vehicle should always be "run in" as this is stated by the manufacturer.
The reason being, not just the tightness of the engine components, but the whole vehicle itself.
All the components such as wheel bearings, UJ's, etc, etc, are brand new and tight.
So running a brand new vehicle for long periods of time makes all the new components get very hot,
whilst still very tight......hense, run in at a steady but not excessive speed.
Running in will make your vehicle last for many more years to come, believe me!
Some people think that because an engine has been "bench tested" that it is run in............utter crap!
It has only been run on a bench to check that the engine runs as it should. It is definitely not run in.
When I say "vehicles", I don't mean aeroplanes, 'cos you can't really run them in at a lower speed really!:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Feb 19, 2018
5,754
91,579
EAST ANGLIA
Murvi Morello
Since 1975
So, taking your hypothesis about everything tight and overheating when new, what happens with aircraft engines? 🤔
Mar 23, 2012
10,172
34,738
sleights
c class
In actual fact the thing that's the worst thing to do with a rebuilt aeroplane engine is treat it too gently it needs variations in power and has a different oil for the running in period. The explanation I heard was that the machining wasn't to a final polish and running in at a slow steady speed can lead to glazing of the bores requiring another rebuild. Slow and steady isn't necessarily the kindest!
From aviation safety magazine
"The trick is to force the rings against the cylinder walls during the break-in process, minimizing lubrication. This is best accomplished by running the engine at high power settings, which generate the highest internal cylinder pressures, maximizing both ring expansion against the cylinder walls and friction"
Just the opposite of what people would expect. If modern engines are designed to be used out of the box with a full range of power settings being too gentle could be bad!
stuartholmes
575
880
Nottingham
Murvi Morello
Since 1989
The oil will circulate sufficiently within a few seconds on start up, I wouldn't worry. I remember people used to rev the engine before switching off years ago so there was fuel in the system for the next start up!!!!!
Those were the days when you would see people at fuel stations lifting the filling pipe to get the last drop out! :LOL:
Modern engines, state of the art lubrication things have moved on.
And all these years I've been thinking it was just me who did that with the fuel pipe...
Jan 30, 2020
3,638
17,013
Mid Bedfordshire
RS Endeavour
Just a tad..
Too hot ??? Most engines are able to regulate their temperature nowadays , I've driven and been involved with stop/start vehicles since their inception and never experienced a "too hot " scenario. Most vehicles are fitted with a coolant to oil heat exchanger and performance engines also have additional oil coolers. Too hot would indicate a malfunction of some kind.
Erm 🫤 don’t know what to say…. No malfunction… I’m not suggesting jeopardy, so for example not the engine overheating and too hot, but outside of parameters for the engine to go off via stop:start too hot! 🙃
My later M5’s both had stop start, but it didn’t operate all the time for the reasons mentioned above. This could be the charge/inlet temperature too high, coolant or oil temp too high, turbos too warm etc etc
May 21, 2019
129
195
South Coast
Bailey Advance
Ahh.... should have got AMGs from the competitor.....
68c
Oct 22, 2019
1,931
3,025
Southampton
2001 Pilote 270
Yes you can, spent many hours running piston engines, then changing the oil. Boring just sitting there. Engineers rarely run piston engined helicopters so the junior pilot gets the job. One of the lads once crawled past the cockpit with a drawing of a cloud on a stick to keep him awake.
