Disappearing fresh water (2 Viewers)
Nov 13, 2017
995
78,928
Pembrokeshire, Greece and everywhere in between
Bailey Approach 750
I have another question for the technical department.
When we fill up with fresh water the read out on the master panel says 100% and water comes out of the overflow under the van. All ok so far.
After we've been driving for a while (typically a couple of hours) it shows anything between 55% and 65% having not drawn anything from it.
There doesn't seem to be a leak (no puddles and no water trails behind us) so it's a bit of a mystery. And also very annoying.
This isn't a new thing, it's been happening since we bought it in November but we though we were just using a lot of water. Until we started checking it regularly before drawing any off from the supposedly full tank.
I hope it's something blindingly obvious that we've just missed.
Any thoughts please and thanking you??
Feb 9, 2008
4,094
5,914
SW Scotland
LP Coachbuilt
I have ignored our water and waste water gauges for years. Rule of thumb, if you put ten litres in the water tank roughly ten litres will end up in the waste tank. After using your van for a while you get a feel for how much water you actually use, we put ten or twenty litres a day into the water tank and take a similar amount off the waste tank or just empty it.
43,332
49,516
It has been know for the overflow tube to be too low in the tank (lazy/distracted installer) and once full and overflowing will act as a syphon draining the tank until the end of the overlong tube is above the tanks depleted water level.
If the tube is 1/4 way down the inside of the tank then 25% of the water will be syphoned off before the level is below the tube and the syphon suction is broken.
If there's an inspection bung on top of the tank get an arm in and see if you can feel the overflow tube inside the tank.
703
19,119
Plymouth
Adria Compact
Do you drain down between trips, if the heater empties as well it can take half a tank to refill. We have been caught out by that before
bigtwin
5,244
9,946
Derby
Concorde
As you drive along, accelerating and braking, there is a lot of sloshing around goes on and a lot of energy therein to expel water out any overflow.
Ian
53,477
150,221
Agree, it could just be bad design, we had a caravan if you filled the tank after 50 miles it was only 50% full.
scousebird
10,926
359,953
South East Kent
Bailey
March 2012
Anthea our Bailey water tank is the same as yours. Unfortunately water leaks out of the overflow when you are travelling. Alan has fashioned a "plung" for ours - a cross between a plug & a bung that he pugs into the overflow when we are travelling. When we first discovered it Alan just used some shapeable ear plugs to block it until he could make his "plung".
Duck Truck
1,203
1,226
UP North
Hobby 725
the water sloshes around
and some is bound to be forced out the overflow as you drive
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
Perhaps as you drive along, the water sloshes around, and can be forced out of the overflow?
Jim
Ringleader
Jul 19, 2007
36,446
131,001
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I agree its likely to be siphon or slosh effect via the overflow. I had it on one van so bad I put a tap on the overflow. When wildcamping and needing all the water we could get, I'd close that tap and fill my square tank so full it would look round. :) . If you do the same be careful.
Offagain
Nov 13, 2017
995
78,928
Bailey Approach 750
Thanks all.
Despite not seeing any water trails I think sloshing and leaking from the overflow is probably the answer. We'll be filling up (again) today so I'll suggest to paul that we try the bung in the overflow pipe option.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Is the water emptying itself out or is the gauge faulty?
To find out which is the problem, fill the tank till it overflows, go for a drive then stop and try and fill it again till it overflows.
If you have to put more in, the overflow may be letting water out (or there may be a leak somewhere else.)
If you can’t get anymore in, the gauge is at fault.
Offagain
Nov 13, 2017
995
78,928
Bailey Approach 750
We always full until the gauge says 100% and there's water coming out of the overflow. Once we opened the tank at the top to check and when the gauge said 100% and it was overflowing the tank was indeed full.
Alhough we didn't think it was leaking I suspect it's the only answer and will try plugging the overflow as previous posters have suggested
32,667
66,624
It can't be a faulty gauge as the water comes out of the overflow UNLESS there is air trapped in which is pushing the water out the overflow, but it is unlikely to have both this and a faulty gauge.
Our Globecar 'overflow' is out of the filler which has gaps in the cap, when travelling it seeps out so we always have water streaks down the side of the blooming van! One thing we have to be careful of when filling is that it doesn't get an air block as that make the water come back out and gives the impression its full, when it isn't, this happens with a hose pipe or using containers and a funnel.
As has already been said, it's just gradually coming out of the overflow as you travel - if you fill it and don't move for a couple of days or use the water it should still show full.
Duck Truck
1,203
1,226
UP North
Hobby 725
Careful when bunging up an over flow
Remember it works two ways
Lets the water escape when it's overfilled
Lets air in as you draw water out
If air can't get back in you can damage the fittings
or perhaps the pump won't have enough power to overcome
the vacuum effect.
I think I would leave well alone
Offagain
Nov 13, 2017
995
78,928
Bailey Approach 750
We couldn't find the outlet for the overflow anywhere accessible in or around the tank so after refilling the tank we've used an ear plug and some duct tape to block it from the outside. We'll see what happens!
bigtwin
5,244
9,946
Derby
Concorde
You need to heed this advice:
the vacuum effect.
For the reasons explained above you may end up in a situation where you have plenty water onboard but are unable to get any out of the taps.
Ian
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Be aware that the gauges are usually measuring the depth of water in your tank and it is quite common for the shape of the tank, vertically, not to be linear. You could calibrate your gauge by adding 10 litres at a time from empty (use a clean watering can) and compare the actual litres put in with the capacity displayed by the gauge. I found that half full on my gauge was actually more like 80% in the tank and the gauge showed only three quarters full when the tank was about 95% full.
If yours behaves similarly, you might not be losing as much as you think as you travel but you could try taking the corners less quickly!
11,956
16,570
I can confirm that can be an issue - it's well worth checking before worrying about more complex problems.
11,956
16,570
If it's the most common type of level sensor it comprises 5 rods: one is common & reaches to the bottom; the others are cut to lengths corresponding to the markings on the gauge (approximately :)). So as soon as the gauge reads 3/4 the tank level is anywhere between "not quite full" and 3/4 full. When the gauge reads 1/2 full the level can be anywhere between just under 3/4 full and only just 1/2 full. For instance on a 200L tank "1/2 full" means there is between 100L and 150L remaining even if the rods are the correct length and therefore the gauge is accurate. "Empty" would mean you have between 0L and 50L remaining.
