Allanm
- Jun 30, 2013
- 5,431
- 9,193
- Burstner Harmony TI 736 G
- Since 1987
We have the same sensors in our tank too. If I brim the tank it shows 100%. If I then fill the kettle, it shows 75%, so the shortest rod only just reaches the water when it’s full.If it's the most common type of level sensor it comprises 5 rods: one is common & reaches to the bottom; the others are cut to lengths corresponding to the markings on the gauge (approximately). So as soon as the gauge reads 3/4 the tank level is anywhere between "not quite full" and 3/4 full. When the gauge reads 1/2 full the level can be anywhere between just under 3/4 full and only just 1/2 full. For instance on a 200L tank "1/2 full" means there is between 100L and 150L remaining even if the rods are the correct length and therefore the gauge is accurate. "Empty" would mean you have between 0L and 50L remaining.
As a bonus though, our water tank is translucent white so I can see the level of the water just by opening the locker door
