If anyone want to do a coil, I did 3 so far not for diesel heater, but for the wood stove. The largest coil was 35m of 15mm copper pipe. Find two plastic caps, fill the pipe with water until water comes out the opposite end. Fit the plastic plugs, ( push fit) work well. Put the pipe in the freezer for 1day. The caps will blow no problem as they just push out. Re fit the caps if they out, and take the pipe out and leave defrost for 1hr max. This is to allow the ice to melt from the interior wall, and allow it to move inside as you bend the pipe. Keep the pipe tight as you wind it on the barrel and you get a perfect no kinks coil.
