Do you mean under the MH? Won't it be exposed to all the road muck?I would mount it under the floor and feed the air pipe in through a sealed hole in the floor. I don't like C0 producing appliances inside the van if not essential
That looks great! Where have you put the fuel tank?I mounted ours under our motorhome behind the fresh water tank and it stays clean and dry, which is helped by the thermal jacket that I covered it in.
Does the second silencer make much difference?I mounted ours under our motorhome behind the fresh water tank and it stays clean and dry, which is helped by the thermal jacket that I covered it in.
Does the second silence make much difference?
Can I ask where you obtained the Exhaust wrap ?It does not double the quietening but does help to reduce the sound level, but wrapping the exhaust pipe in exhaust manifold wrap does absorb a good amount of the noise that radiates out from along the pipes length.
I fitted the extra silencer and exhaust wrap to try and reduce any annoyance to anybody that we are parked near when our diesel heater is running, especially on start up.
eBay, it's surprising how much you use with overlapping, but 10 metres is more than enough.Can I ask where you obtained the Exhaust wrap ?
Just waisted more of my time watching this and found it interesting.Bob.
Vevor are the Chinese diesel heaters in the photo deemed as "unsafe" by trading standards in this recent thread.
Caution! Diesel heaters warning from trading standards
Trading standards have stopped the import of some Chinese diesel heaters. Mainly for instruction problems.www.motorhomefun.co.uk
That's a little misleading. It's not the heaters themselves it's the lack of coherent installation instructions that has been deemed unsafe.Vevor are the Chinese diesel heaters in the photo deemed as "unsafe" by trading standards in this recent thread.
Joppa Cornwall?Have ordered a heater off ebay. Just now been out to the van and had a look at where I could put it. There's a good place under the side seating as there is space next to the water tank - its near the batteries and would be very easy to connect to the heating ducts but there is no room for the fuel tank in there. There's definitely room between the passenger seat back rest and the couch but don't think its a good idea for it to be out in the open and anyway swmbo would not like it sitting just behind her. I don't think I would either!
I suppose I could put the fuel tank in one of the back lockers and run the fuel pipe under the van to the heater from there but was wondering if having such a long length of pipe would be ok.
The other option is to put both the heater and tank together in the rear locker and but not sure then how I would get the heat to the van. Would mean a long run of wire to the batteries though.
i am surprised that more use isnt made of the heat from the exhaust pipe. if the exhaust was wrapped in a coil of copper piping and water fed through it, i assume it would act just as coil does in a hot water cylinder (only in reverse)? possible enough heat to heat up a small radiator/heating pipework (as used in an Alde system). if the water content was kept to a minimum then it might be more efficient use of the wasted heat.
It had crossed my mind, but I think that for the most part that it's complicated and more hassle than it's worth.
Bobil Vans produce a water heater unit that uses a heat exchange in front of the diesel heater house outlet.
Product Page | Bobil Vans
www.bobilvans.co.uk
My cdh has its own 75 ah battery, kept charged from a 100w solar panel.The main thing to ensure is that there is no danger of the power supply to the heater being turned of say through the habitation switch. It is important that when these heaters are turned off they are able to go through the correct shutdown cycle. Where the fuel is stopped but the heater continues to run the combustion and air flow fans until below a set temperature. Otherwise damage to the heater may be caused. If it were me I would connect direct to the batteries.
Apparently they reckon the 5kw is best, and I just saw Amazon advertising them on a FB page for £139.99.Pretty much getting my MH set up for when my wife and I retire next June. Am planning some projects for the Autumn one of which is to get a diesel heater for the MH. Have done some research and looked at a few youtube videos and it seems that the Chinese heaters are cheap and effective and easy to fit so am going to order one from ebay. A couple of basic questions though. Firstly my old 1997 Hymer is 7 metres so would a 2 or 5 kw be best?
Secondly I think I'll be ok fitting it but for connecting it to the electrics a couple of sites that I've been on are saying that it should be connected directly to the battery. I would have thought it should be connected through the elektroblock, so any advice on that would be gratefully recieved.
Cheers Martin
Lovely tidy looking installationIt does not double the quietening but does help to reduce the sound level, but wrapping the exhaust pipe in exhaust manifold wrap does absorb a good amount of the noise that radiates out from along the pipes length.
You may find this video interesting.Does the second silencer make much difference?
MisterB further to your interest in recovering exhaust heat loss and making use of it, I came across this video that might be of interest to you as it was to me.
Two on Tour
Seems my idea has already been successfully trialled ....
In an earlier video he is using a domestic radiator but have had chance to check out what his heat exchanger is though ?
I understand, but it might be viable for one at a static van to feed a radiator/skirting heating or even at home ....?I watch that one sometime back when I was all enthusiastic about getting all I could out of our heater, but then reality kicked in and I realised it was more hassle than it was worth on our van with routing pipework, finding a position for a heat exchange and fan, fitting a water pump, a thermostat to control the water pump and fan, and an expansion tank.
