Comfortmatic gearbox
Ours is 4 years old and worked fine. Often use the manual override too without any issues. I’ve had auto cars for several years too so was happy to go for the comfortmatic.
It’s not complicated to drive and after a couple of trips will be second nature.
Not dismissing people that have had issues, but you do tend to hear more about problems than positive experiences. Which is the same for lots of vehicles.
If it’s been well maintained then go for it, beats driving a manual.
I’m sure there’s lots of happy owners and we only hear about the failures. However, I’m not sure I’ve seen as many manual gearbox problem threads.
I suppose it’s the frightening costs involved when the Comformatic ones go wrong.🤷‍♂️
13k on the clock with ours and no problem.
My personal opinion, I wouldn't touch any robotic gearbox with a barge pole, having driven trucks with the same. Why buy a comfortmatic when they are known to have problems that can be expensive to repair and you will need to adapt your driving style to suit the gearbox? If you want an automatic buy one with a torque converter you'll be able to enjoy your trips without worrying if you are going to be one of the unlucky ones.
Perhaps but I bet the total number of failures is a small percentage by comparison to the amount on the road. And some on here are the same tales just retold every time somebody new asks. I see on some car forums.
Newish member here 👋 we are in the market for a used MoHo, I would prefer an auto, at my price range that means mainly the only one will be the Fiat Comfortmatic, how bad are these? There are a few horror stories about but I would like to find out from the experts on here as to their thoughts, I know there are a couple of other makes like ford or merc but most seem to be the Fiat
Ignore all the bad news stories, they are a great gearbox, possibly better than the merc auto…
many of the horror stories stem from user errors…
what do you mean by ”Adapting your driving style”. I’ve been driving auto cars for many years and don’t believe I drive differently in either. Apart from the fact one weighs more than twice as much and handles a bit differently in the bends!
When I’m researching buying something, I take into consideration the top and bottom reviews, but concentrate mainly on the middle ground. I’m not sure I see any middle ground with the Comfortmatic.
I don’t see too many problems with manual gearbox’s. And if I do, they are significantly cheaper to repair / replace.
I’ve taken a number of cars to well over 100,000 miles and motorcycles over 50,000miles, all manual. Only ever had one gearbox issue. That was in a car with 160,000 miles on the clock.
Robotic gearboxes tend to change gear just when you don't want them to in my experience, and also tend to change gear slower with a slight pause before drive is restored, just what you don't want when joining a busy roundabout or pulling into traffic, which means dropping into manual mode to negotiate these circumstances, that is adapting your driving style, with a torque converter box the power delivery and changes are smoother.
now we learn the 9 speed auto from fiat may soon be dropped !
I think that's Stellantis trying to move every brand to use the same engine and running gear. I think only the Fiats had the 2.3 with the ZF 9 Speed? It sounds like there's a suitable Citroen-Peugeot engine that they have an in-house automatic box. So I'm guessing all brands will use that engine going forwards. It might make the auto option cheaper than the £3.5k plus non optional extras that they currently charge now.
Mechanically, the Comfortmatic and manual Ducato gearbox and clutch are the same. The only difference is in how the selector on the outside of the gearbox is operated. The bigger difference is how much garages can get away with BSing owners if things go wrong 🤬
I had a Merc torque converter auto on my last motorhome and driving my current Comfortmatic is nicer than the Merc.
The Merc auto was just the same, the ECU drops the power to help the gear change on both of them.
If it suits you that's fine, my merc auto doesn't drop the revs and neither did my Mitsubishi Delica, both are a smooth as silk and the Mitsi did over 200,000 miles with no gearbox issues at all.
The only naughty clog dance is to us the brake pedal left foot to set off (ie: foot on brake with revs rising then release brake pedal to move off). It plays havoc with the calculation of the clutch transmissibility index calculated by the Comfortmatic control unit and causes the clutch to open or close at the wrong bite point which could promote wear or even mechanical damage.
Stick yo one foot driving, you won't have any problems. On the Comfortmatic you can't increase revs if your foot is on the brake. In fact it causes a problem if you are inadvertently touching the brake pedal at the same time as trying to pull away.
That's what I said?
On mine the engine cuts out.
That's what I said?
Did you? I couldn't really tell what you were saying. You mentioned using a left foot on the brake. That's not a thing you should do with any automatic.
read his post again.
That's what he said 👍
I’ve had loads of problems with my comformatic, loads of them.
But 100% of them are user error. Usually “Put your foot on the brake before moving the stick fatty” or “How many times do I have to tell you to leave me in 1st gear before switching me off idiot“ 😳😳
I also get “put someone else’s foot on the brake you legless barsteward”
I’m an idiot, I still leave it in neutral…..😆
Oh yeh, I forgot about that shorty :rofl::rofl:
Ive got a fiat 2.2 with a 9speed auto, undersatnd a ZF product? Are Stelantis phasing them out too?
the 2.2 is actually a Ford, with timing chain, so no 5 yearly £1000 bills!
Not sure that the bit about it being a Ford based engine with timing chain is true. Having done a quick scan of the Fiat Forum there appear to be differences between the Fiat 2.2l and the Peugeot/Citroen 2.2l engines. The discussion here
https://www.fiatforum.com/threads/new-ducato-engines.493446/
starts off making the same assumption that moving from 2.3l to 2.2l means they are now the same engine. However as it progresses it seems they are not and that there are significant differences.
A bit more reading and I see that Fiat are claiming it to be “An all-new engine, that offers improved consumption and emissions with an optimised weight.” They also claim “a reduced noise level.” Lighter weight and quieter would be consistent with a belt perhaps more than a chain but I have seen nothing to confirm either way. What does seem clear is that Fiat are not using the Ford engine which has a slightly different cc. My guess is that with time Stelantis will adopt the new Fiat engine across their whole range of manufacturers.
