Recently I had issues with my comfortmatic gearbox as a result of contamination in the master/slave cylinder. Had no clutch at all. Had to be recovered to the garage by the AA. Cost £3,800 which fortunately the warranty paid for. The difference in drive quality was amazing. Had it done at Adam’s and Morley in Portsmouth.As other have said. Become a member and read some of the many comformatic threads. You could well save the joining fee many times over. Other than that Adams and Morley in Portsmouth are the trusted comformatic dealers I believe and that's who I used before we changed vans.
Be warned you may need a stiff drink whilst reading them. Good luck hope you get sorted.
Not true. Clutch fluid does not need replaced every year. Hopefully the ignition switch on/off tips helped because I have had it twice and both times it worked.Hi Has the clutch fluid been replaced every year . This is essential as can lead to sludge and affect the gear changing. First place to look is your service schedule and receipts.
Hi does it say on system transmission failure? Are you able to drive it?Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
with a comfortmatic gear box, i have a warning light and a message on dashboard saying no
gears available? HELP PLEASE
I had that a few times..... 2 times it wouldn't drive and had it recovered to Adam Morey ( Southampton ) £700, when it happened again, due to this website, took it to Portsmouth..... fine ever since !!!Guess I was lucky I took the van out yesterday and all was fine
Pre 2020 (or 21?) comfortmatics, or post 2020 true autos?now i have been reading threads to the missus its at last sunk in with her .to stop looking at auto fiats..she says come on babes you cant take it with you i said i can if i dont give it to fiat
stick shift for me all day long .its saves arguments when we are driving ,she talks to me and i dont have to say a word just the way i change gears and the length of time between change and shake my head and mutter under my breath.its not the same in a autoPre 2020 (or 21?) comfortmatics, or post 2020 true autos?
The two are very different.
Read the 3rd thread up . I had the same problem but not under Warranty! Cost me £3.5k Advise was keep the fluid changed yearly. Up to you .Not true. Clutch fluid does not need replaced every year. Hopefully the ignition switch on/off tips helped because I have had it twice and both times it worked.
A/Morey said to me ,change every 2 yrs going get mine done there nxt Yr, Van is 5 yrs old don't know if it's ever been changed !!!!Read the 3rd thread up . I had the same problem but not under Warranty! Cost me £3.5k Advise was keep the fluid changed yearly. Up to you .
He Quoted me I think it was £145 for a Clutch Oil change !!!!Changed mine early this year. Simon at AM told me that you need your Comfortmatic fluids changed and re-bled every two years. I asked him, how often does he change his. He said annually.
If I had the time and the money, I would go for annually, but I wouldn't let anyone except AM do the work, and they aint cheap, so biennially it is.
I am more than happy that I got rid of our comformatic. We had the van for over 4 years with no problems. But I was not happy with the potential small things that were costing people an absolute fortune to repair and the uncertainty this gearbox gave me with people who actually know what to do to repair it very limited.Recently I had issues with my comfortmatic gearbox as a result of contamination in the master/slave cylinder. Had no clutch at all. Had to be recovered to the garage by the AA. Cost £3,800 which fortunately the warranty paid for. The difference in drive quality was amazing. Had it done at Adam’s and Morley in Portsmouth.
Correct Richard. If every 12 month change is good enough for Simon at Adams Morey it’s good enough for me ‘cos he’s got one.It's not just an oil change,they hook it up to a computer and re calibrate the clutch,I think you'll find everyone who has had it done thinks it's well worth the money.
Glad your HappyI am more than happy that I got rid of our comformatic. We had the van for over 4 years with no problems. But I was not happy with the potential small things that were costing people an absolute fortune to repair and the uncertainty this gearbox gave me with people who actually know what to do to repair it very limited.
Good riddance to it
The same procedure will cost you 300 euros in Ireland???He Quoted me I think it was £145 for a Clutch Oil change !!!!
If your dot 4 clutch fluid has gone black and thick, switching off/on etc will not cure it. The actuators cannot move quickly enough for the ecu, hence it throws up the fault messages. All fluids don't go black hence this method works sometimes.You've probably already done this but try turning the engine off and trying again.
If that doesn't work, disconnect the cab battery, wait 30 seconds and then reconnect it. This will force the transmission control unit (TCU) to reboot. But if you have a batterymaster or some other device to top up the cab battery from the leisure batteries you will need to disconnect this first.
I shall be travelling down to Adams Morey in Portsmouth, after talking to Simon there he was very helpful / Knowledgeable knowing what he was talking about & even though it's quite a distance will make a trip out of itThe same procedure will cost you 300 euros in Ireland???
I shall be travelling down to Adams Morey in Portsmouth, after talking to Simon there he was very helpful / Knowledgeable knowing what he was talking about & even though it's quite a distance will make a trip out of it![]()
The West MidlandsDo you mind if I ask where you’re from when you say it’s quite a distance
The West Midlands
