They do in the same way as older engines did. But nothing like the amount of braking that would be available with the throttle wide open with no fuel being burned.Are you saying that modern engines don’t have engine braking?
Ian
Ian
The brake fluid was changed about 6 months ago...
The brake fluid was changed about 6 months ago... but I suspect it was the first time it had ever been done in 12 years. Could they have flushed the brake circuit, but left old fluid in the clutch end?
Ah, so if I took the van to my friendly (non-Fiat) car mechanic, is it possible they only bled the brake lines and not the clutch slave?There's a bleed valve on the clutch slave cylinder body where it projects externally from the clutch bellhousing. Although the owners manual refers to changing the brake fluid, the operation as described in the dealer manual includes brake and clutch fluid replacement and bleeding. Whether they can actually be bothered to do both is another matter...
