Chinese water heaters? (3 Viewers)
Apr 15, 2024
16
10
Converted Volvo coac
Are these 18L water heaters any good?
MisterB
5,956
13,313
Adria 670 SLT
I assume it's gas (lpg?) because of it being 36kw ....and the dial on the left, though it's difficult to read ...
Looks like it could be useful as a static caravan heater, though a combi type boiler that also provides heating might be preferred in the UK.
G0HWC
Apr 15, 2024
16
10
18L Tankless LPG Hot Water Heater Wall-Mounted for Camping Showers&Trailer White
Features
✅High Performance - Power: 36KW; Hot Water Output: 18L/min; Gas Supply: LPG(Liquid Propane Gas); High-temperature resistant copper water devices, ensure long time use & durability of this tankless water heater propane.
✅On-demand Endless Hot Water - Maximum power output 18L/ min, get instant endless hot water easily wherever you are. No need to preheat before using RV camping water heater. As soon as you turn on the tap, the water flow with your desired temperature. Applicable water pressure is from 0.02-0.8 MPa pressure, low water pressure can make it work and enjoy instant hot water.
✅Summer/ Winter Mode - This gas instant water heater can also provide summer/winter mode to select for energy saving. Gas control knob: clockwise to increase gas supply. Water control knob: clockwise to get more hot water. Summer & winter knob: designed to save 40% energy(shut off 1/4 fire rows in summer).
✅Wall-Mounted Design - Portable design for carry on easily. It can bring a amazing hot shower for you when you are camping , to the beach, etc. Also you can wash your pets with this portable hot water heater in your garden.
Description
Technical specifications:
Operation: rotary knob
Power: 36KW
(25 ℃) Hot water volume: 18L / min (18 kg / min)
Flow rate: 4.8 GPM
Gas type: Liquid Propane Gas (LPG)
Rate gas pressure: 2800Pa
Fire -extinguishing: Automatic fire extinguishing with electrical pulses
Exhaust options: Automatic exhaust gas
Exhaust outlet diameter: 18kg F110
Applicable water pressure: Min.0.02MPa, Max.0.8MPa, Starting pressure: 0.015MPa
Gas line (inner diameter): F 95mm oil-resistant rubber hose
Cold water pipe: short pipe or G 1/2 steel pipe
Hot water pipe: Long pipe or G 1/2 steel pipe
Dimensions: 610 x 360 x 150 mm (H*L*W)
Package size: 720 x 410 x 210 mm (H*L*W)
adjustable amount of water (stepless)
adjustable temperature (stepless)
Color: white
Display: LED digital display
Advantages:
No pilot flame!
No power connection required!
Advantage 1: easy installation! (in a ventilated environment)
Advantage 2: automatic ignition by two D batteries (not included)
Advantage 3: Portable and light. no power connection required
Advantage 4: instantaneous water heater
Advantage 5: Heat-resistant metal housing
Advantage 6: Start at low water pressure
Advantage 7: Overheating protection, No water storage required.
Advantage 8: come with the shower head and shower hose.
Advantage 9: ISO Approved and CE Certificate
Package includes
1x water heater
1x shower head and shower hose
NOTE: 1. This water heater can only be installed in an outdoor ventilated place, and it is strictly forbidden to use it in a confined space. 2. Please confirm the type of gas used at home (liquefied gas or natural gas) before purchasing, and pay attention to the model you purchased.
Payment Shipping Returns Contact Us1. All payments must be prepaid.
2. We only accept payment via Paypal. Please kindly check if you can do the payment via ebay before placing an order,Payment must be received within 7 days after order is made.
Al-Di
3,064
28,979
prestwich
Eura Mobil A Class
since 2013
Fitted 16ltr version in horse box conversion,works great from LPG, needs good water pump 30psi for decent flow
RedFrame
1,297
3,686
Chester
Self Build W907 PVC
Sept 2017
I thought the same Jim, never thought of gas.
I doubt a gas bottle and regulator would never allow enough gas through for 36kw so only suitable for mains supply.
It's rated at 2800Pa, your gas regulator is 3000Pa, I'm no expert but surely that is within tolerances...
Cheers
Red.
Gellyneck
9,275
18,431
More than toes wet now!
PLEASE NOTE: These do not have a balanced flu and are not safe to install in any enclosed space. Must have plenty of ventilation.
Was just about to say similar -
G0HWC
Apr 15, 2024
16
10
What water pump did you use?
Can I use a pressure switch with pump so will get water on demand from tap?
Al-Di
3,064
28,979
prestwich
Eura Mobil A Class
since 2013
Shurflo 30 psi,used domestic style taps, copper pipes soldered fittings
Jan 2, 2024
432
539
Lincolnshire, UK
Peugeot boxer
They are great,I had one for the shower on our CL.(Circa 15yrs) ,worst problem is they need a good flow of water to get a sensible temperature in summer,so you'll need a decent size storage tank.Also have 1 in our property in Spain.
Still got a new one that I bought as a spare for the CL,never needed it.And a second used half a dozen times in PVC,(Found it needed more water than was convenient to carry for off site use),so changed it for a carver with added digital thermostat control.(have 2 spare carvers for future part of needed)
Jan 2, 2024
432
539
Lincolnshire, UK
Peugeot boxer
If you decide to fit one,put it back to an outside wall use Flexi Ali pipe for flue sealed to wall,vent low down and build airtight cupboard lined with plasterboard or other fireproof material, should be only accesable from outside to comply with regs .
