No problemCool,
that seems the perfect solution and not too complicated.
Will order one of those leads asap
Thanks for the info
Graydo
One more question, would the solar panel still charge the leisure batteries with the kettle plug removed/isolated?Fridge would still have 240 to it but you just manually select gas.
There will be a normal trip consumer unit that you could throw the trip to fridge but really not needed just switch it to gas
In most vans it should, as on most I've seen it's directly wired to leisure battery via the charge controller.One more question, would the solar panel still charge the leisure batteries with the kettle plug removed/isolated?
The other limiting factors, in addition to the cassette is, the amount of sun and driving (in the winter months) but you already knew that.Quick update,
Patch cable came today and fitted this afternoon.
When the eco flow is connected to ehu and the charger isolated I Can confirm that-
The heating works
The fridge works on gas (leccy too, but not for long on the ecoflow)
The i-net box works and accepts commands remotely as normal
The lighting works
The mains icon in the control panel does indeed NOT illuminate
The tracker works
The alarm works
The solar panel and shunt works and does indeed continue to charge the leisure batteries from solar panel.
Once the ecoflow unit is connected it shows zero draw until I use one of the 3 pin plugs.
With the ability to charge the ecoflow at night from the 12 v socket and leisure batteries (which in turn will recharge during the day from solar and driving) this should simplify electrical needs for future stays on aires/stellplatz.
Thanks again for the valuable information.
Only limiting factor now is how often I need to empty the toilet cassette but that's another story......
Cheers
Graydo
Many things affect the cab battery.The other limiting factors, in addition to the cassette is, the amount of sun and driving (in the winter months) but you already knew that.
As you know, I know little of electrics of any kind but am trying to learn so have been reading some books to try and sort out a constant voltage leak on my 2023 Starter Battery
(Down from 12.85v to 12.67v in 24hrs) and I read in this Boat Electrics Book, just how much difference the Solar panel angle to the Sun truly makes.
It's tremendous! (but the book is about is about 15yrs old)
I took have just acquired a Power Pack and, like you, am experimenting how best to use it.![]()
I am fortunate that in the worst of the winter I can park the van outside my house and run a cable to it with the heating on low.The other limiting factors, in addition to the cassette is, the amount of sun and driving (in the winter months) but you already knew that.
Thanks,Many things affect the cab battery.
Radio, even when off can sapp power.
Tracker if fitted
Alarm if fitted
The electronics that dont fully go to sleep, remote door lock etc.
Age of battery, how well it has been maintained etc.
Battery master or almblemail trickle chargers shiuld be enough to keep it a float. Or a dedicated solar just for cab battery. Smallish cheap one as it dont have that much work to do
Tried a cheap one from Halfords, it didn't seem to work.Many things affect the cab battery.
Tracker if fitted
Alarm if fitted
I have the ecoflow 100 watt version solar panel, when folded, it fits nicely into the rear cupboard on the van.We may do saem this weekend, we leave tmrw, and it's so hot, we are thinking of taking the ICE machine which has a 10A constant draw on the 12v... We'll run it with our solar ocnnected on the array in the day (it'll still discharge slightly) then recharge using the leisure battery and the 12V 10A socket in evening, rinse, repeat, that way we'll be using the roof solar AND the solar array (portable) connected equally, and exercising the leisure battery a little. I'll probably set the delta2 for 60W charging when not using solar.
Cool,
Thanks for the info
Graydo
I am hoping that I can get away with just using the 100 watt panel on the roof though, but its a case of trial and error.
Graydo
Must have missed that question, the glass reduces the light by about 10%, so not much effect really. It has a bigger effect on the infrared and UV parts of the spectrum, but solar panels mostly use the visible part which isn't affected much.Someone told me that Solar doesn't work well behind windscreen glass but when I asked on here about that, no-one answered.
The problem with a bigger panel is trying to avoid shadow on it - a small bit of shadow can cut the output a lot.Appreciated that, I will now add a direct link to the Starter battery under the passenger side footwell and lay my 100w folder across the front seat while it's parked on my driveway.
I will only get direct sunlight for a few hours but if a small panel will do the job, hopefully the 100w will be more than adequate?
In my case the kettle lead was behind a heating ducting pipe and a ton of wires and a hinged vent.I have done this to run the fridge off the batteries (via inverter)
It really is a simple as unplugging the electroblok (personally I think pulling the lead out is as easy as switching that switch!) and putting the fridge onto manual and selecting gas.
The fridge's electrics for the control panel will still run off the battery.
I noticed that, as my driveway where the van is parked faces roughly North and my folding panel has two panels, I had hoped to have one facing towards the East for the morning sun and one facing East for the evening sun, and had hoped to get about 40w from either.The problem with a bigger panel is trying to avoid shadow on it - a small bit of shadow can cut the output a lot.
I am interested to know how well this works.I have a permanent 10 amp 12 volt socket in the back of the van which will charge the ecoflow delta 2 with the appropriate cable from the leisure batteries (two 110 lithiums).
The leisure batteries are replenished with the 100 watt solar panel on the roof.
Just got my small Halfords one that looks very similar and placed it in the West passenger window which seems to have the best sun amount and connected it directly to the Starter battery so we will see?Windscreen solar
When I used to go to Oz for6+ weeks, I always came back to a flat battery.
I got one of the little AA ones plugged into the OBD port - and never had a flat battery from there on.
I'm not claiming it fully charged the battery but it partially compensated for the parasitic drain.
So I'm sure a larger panel even if not ideally positioned will deliver something.
So am I,I am interested to know how well this works.
I have just purchased a Bluetti AC70 power bank and intend using this method to charge it.
We currently have 230W of solar and two 100ah AGM batteries.
I am concerned that the AC70 would drain too much power from the leisure batteries when charging, but I would only connect the AC70 when the leisure batteries are full and the sun is shining. (The AC70 capacity is approx 60ah). Do you see any problems with this?
That's the 'Open Circuit Voltage' Voc. A solar cell doesn't behave like a battery or or battery charger. If it's connected to a low resistance device like a battery, the voltage drops to the battery voltage, and gradually rises as the battery becomes charged. If it's a low power panel (up to 30W or so) it won't produce enough milliamps to raise the voltage enough to harm the battery. But anything bigger than about 30W needs a solar controller to avoid overcharging.I put my multimeter onto the connections before I connected and it read 22v in bright sunlight, is that correct?
My friend used to have one unit a Bluetti AC200P which died a death and Bluetti customer service is so bad that they gave up with them and I decided that for something like that I wouldn't put all my eggs in one basket. The Ecoflow I bought was a refurbished one still with full warranty it’s the Delta 1060W so light enough to carry around, bring into the house etc for power cuts (we get a lot). The Jackery again is the 1000W version (again light enough to move around) and I managed to get a good deal so my costs for that incl solar panels was circa £1500. I am a landscape photographer so use them a lot for that, even on day trips hanging around in the early morning in the middle of nowhere to get those dawn shots!You seem to have a very expensive setup, must be at least £3000+ yet you still use EHU hookup sites?
Can I ask why because, even before I purchased my one S/H PowerPack and free standing Solar panel, I used very little EHU during the summer months and only paid a maximum of £5 per night extra for reliable 230v electricity during the winter months when I camped for only about 60 nights all winter and so that's £300 a year.
The cost of your setup would last me years because, if your anything like me, you will buy extra Solar equipment to try and improve what you already have.![]()
That’s a good idea, thanks for that.No need to go to a camp site if it's so quick. You could charge them up from an EV charging point. You can get a special cable that connects the EV charger to the round blue EHU inlet, so you can probably charge everything up in a couple of hours. Then you'd be OK for a couple of days at least.
The two 100Ah AGM batteries can be discharged down to the 20% level, so that means you have about 160Ah usable charge from the total 200Ah. The AC70 would take about 62 to 64Ah to fill the AC70 from flat to full, so the leisure batteries should be able to supply that easily, depending on your other consumption.I have just purchased a Bluetti AC70 power bank and intend using this method to charge it.
