andy63
I had a google at the instructions of said battery to battery and of the various wiring diagrams I could see it does appear as you say there should be a negative used from each batterybut why provide 3 negative connections instead of 1 if the second circuit didn’t need one. At present neither of the right hand pair appears to be in use.
also mentions the unit won't work if the temp sensor switch is in the on position but no sensor is connected.
900001_Instruction_manual_Booster_WA_121525_EN.pdf
Andy
