eddie
OK, So before you do anything else, get the battery tested
I'm not sure that's so..your hab batteries are been charged when on hook up and charger is on.. that been so then if the engine battery if not been charged the fault could lie in the electronic circuit that sees to the engine battery receiving its maintenance charge.. that is part of the ds300 type cbe unit..the part with the 12v distribution fuses..It does look likely that the problem may be the charger.
That's interesting, our cab battery is often one blob down compared the hab ones which are usually 100% and we have 2 x 100w solar panels, hubby mentions it occasionally but so far it's never lost more than one blob, however as we have EHU at home we can just plug it in as/when necessary. Our batteries never ever get as low as the OPs though so once the battery is swapped out it will be interesting to hear what the difference is.The CBE unit used in the Carthagos provides a maximum of 2A to the engine battery and gives priority to the leisure battery. My engine battery always sits at a much lower voltage than the leisure battery, one or two green blobs compared to the leisure with all the green blobs lit. However it never seems to drop out of the green altogether.
Another factor may be the smart alternator system which I think you will have on a brand new motorhome. I read on another Fun thread that in some systems the engine battery voltage is allowed to drop so that energy recovery can be used when engine braking is occurring. May well be worth asking the Fiat Professional about this.
The link about the battery only being charged to about 80% is interesting. It sort of explains why it has stayed at 12.2v. It also explains why the battery might show 12.6 - 12.8v after being driven for a while and then drops to 12.2 within a few hours. But I have had a few occasions where it has gone down to 12.0v whilst it was plugged into electric.Paul Frost I think your dealer may be right and the system is ok. My 2019 Carthago does not have the Schaudt WA121525 Booster and this has probably been added because the vehicle has a smart alternator. The Booster looks after the leisure battery and the Fiat ECU looks after the engine battery, at different voltages. It keeps the 2 systems separate. On the control panel you should expect the engine battery to have fewer green blobs than the leisure battery. I would only start to worry if the engine battery falls to no green blobs.
autorouter put me right about smart alternators and battery voltages on this thread. https://www.motorhomefun.co.uk/forum/threads/b2b-preference.212700/page-2#post-3702056
at #59. I was wrongly thinking the engine battery should be charged to a higher voltage. I suggest caution before you change anything.
There is a lot of new stuff to understand and I am no expert. The vehicle manufacturers seem to have got away with creative interpretation of the emission rules until now but the new tests are forcing them to use AdBlue and smart alternators. I think the regenerative bit is to do with how much power is wasted by an alternator, so they leave it idle adding very little load when the engine is working hard. However as soon as the ECU senses braking the alternator is worked hard, which adds to the engine braking and uses some of the energy that would otherwise be wasted in the brakes to charge the battery.I'm also puzzled by this stuff about "regenerative braking" and the need for the battery to be kept low so there is room for this excess charging.
I went for a drive and the vehicle battery is now at 12.75v.
I've checked the voltage at the DS300 unit and B2 went up from 13.46v to 14.37v. B1 was 12.75 for both. I'm guessing that as B1 was already way above the 12.2v it's not getting any charge at the moment. I'll check them again tomorrow.
This thread has been really useful in understanding what's going on and why.
It went from 12.7 to 11.6v within 18 mins of being plugged in, then down to 11.28v 2 hours later.Irrespective of the charging regime which sounds all wrong anyway, 12.2 down to 11.0 Volts overnight suggests a problem
When you say the distribution board I assume you mean this, the DS300?I suspect it does..your problems def seem to stem from a issue with that simulated engine e run signal..the fuse you say keeps blowing..
There may well be a problem on the distribution board causing that to happen..you say the pump started running for no apparent reason.. the relay fir the pump is part of the cbe board..
To me it seems to be pointing to an issue there..
Andy..
That sounds like a fault on the CBE charger and it is putting a load on the battery.It went from 12.7 to 11.6v within 18 mins of being plugged in, then down to 11.28v 2 hours later.
Yes..When you say the distribution board I assume you mean this, the DS300?
Its possible..but I couldn't explain how im afraid.. stuck relays etc..But do you think a fault with the DS300 also drain the vehicle battery when plugged in?
I reckon you have the same fault that we had on our CarthagoIt went from 12.7 to 11.6v within 18 mins of being plugged in, then down to 11.28v 2 hours later.
They didn't remove the battery to test it but attached a diagnostic device, which he said tested more than just the voltage. But the major problem seems to be related to when it's plugged in.
I did look at this for a fuse that I could pull to isolate the toilet flush pump, so that we could still have running water. But couldn't find anything.
So what was his diagnosis?It went from 12.7 to 11.6v within 18 mins of being plugged in, then down to 11.28v 2 hours later.
It could be ..but if he can read both battery voltages at the cbe board that would indicate that the start battery is still connected to the board..if the main fuse was gone surley that wouldn't be possible..I reckon you have the same fault that we had on our Carthago
Fridge not working on 12v and leisure battery not charging whilst driving
It was the 50a fuse on the engine battery which feeds to the split charge relay.
Looked ok at first glances, but when removed and replaced was found to be faulty
I checked the fuse with a multimeter and it's OK.I reckon you have the same fault that we had on our Carthago
When the Fiat dealer tested the battery it was probably fully charged as it was after a 50 min drive to the garage.So what was his diagnosis?
You can only test a charged battery
My £800 Battery Test Computer to me that! ;-)
Did I ever mention that 44 years ago my first job was actually making batteries and filling them with acid in the Newton Abbot branch of The Longlife Tyre and Battery Company.
My £800 Battery Test Computer to me that! but I knew that as my manager Peter Arscott told me 44 years ago!
But that is only for charging the hab batteries from the alternator and that's working.I continue to think the missing second negative connection to the WA121525 may be the problem, see #53 above. As I found out when wiring a similar device it can be a mistake to assume that the two negative connections are common within the device. I can even see that failure to ground the second circuit might cause problems with the D+.
It seems hard to believe that a company the size of Carthago would have got this wrong, and wouldn't it mean that all owners would be having the same problem?I continue to think the missing second negative connection to the WA121525 may be the problem, see #53 above. As I found out when wiring a similar device it can be a mistake to assume that the two negative connections are common within the device. I can even see that failure to ground the second circuit might cause problems with the D+.
I was thinking that with one of the circuits being incomplete perhaps one of the internal relays was not opening or shutting as it should which was compromising the engine battery circuit and possibly the D+ too. If the D+ was turning live when it should not it might also account for the fuse blowing. The unit has 3 negative connections, 2 on the Ausgang side and 1 on the Eingang side. This suggests to me that it allows for 1 negative grounding on the paired 2 on the Ausgang side, with a short loop across the divide to the single one on the Eingang side.But that is only for charging the hab batteries from the alternator and that's working.
The fault is when on EHU, hab batteries charge but starter battery discharges.
I agree but mistakes can happen. This could have been an isolated mistake by someone who was new to the device. Carthago are new to the complications of smart alternators because until recently Fiat turned the smart alternators off at the request of constructors. It made charging leisure batteries more complicated.It seems hard to believe that a company the size of Carthago would have got this wrong, and wouldn't it mean that all owners would be having the same problem?
