thekindnesscoach
- Dec 6, 2022
- 5
- 1
- Fist Auto Apache
Can you start motorhome to warm engine while gas is turned on?
I’m sorry but are you reading these helpful replies or not?Thank you for your feedback, so are you also saying it is okay to turn in the engine whilst the gas is in? Thanks
What would the difference be? heating takes air and any other gas into the combustion process, so we are back to the definition of "naked" flame, and it is on the outside of the appliance not the outside of the vehicle.As I read it the allowable use of gas in certain circumstances is ONLY for heating, not for a fridge ...
I think we are viewing these regs in the context of garage forecourts, re-fuelling and fridges in particular as it affects most of us but this is covered by different regulation and for good reason, so it may be legal to use a fridge on the road but certainly not on a garage forecourt.I suppose, unless it’s been tested in court, who’s right?![]()
A filling station near us was blown up some years ago due to an idiot running his fridge on gas.
Hi, maybe I read this wrong, but I feel he means that your compressor fridge stays working on even a long ferry crossing whilst you have to turn the gas bottles off so a 3 way fridge stops working on ferries. I don't think you would ever use the other gas items (boiler/hob) whilst at sea?? Compressor fridges are so good if you have enough 12v battery and solar. Not good if you don't!Not if you have a gas hob, oven, boiler etc.
I was thinking of the 'general' use of gas not being an issue, not just on ferries, ie they'd still have some gas appliances as they won't have a no-gas MH/camper*, just not a fridge. It's down to interpretation and knowing exactly what the poster meant ... which as we've shown can have 2 different meanings.Hi, maybe I read this wrong, but I feel he means that your compressor fridge stays working on even a long ferry crossing whilst you have to turn the gas bottles off so a 3 way fridge stops working on ferries. I don't think you would ever use the other gas items (boiler/hob) whilst at sea?? Compressor fridges are so good if you have enough 12v battery and solar. Not good if you don't!![]()
It doesn't matter as it stipulates 'heating' so that's what I'm talking about, it doesn't say MH/camper fridges can be used, either with or without a naked flame.What would the difference be? heating takes air and any other gas into the combustion process, so we are back to the definition of "naked" flame, and it is on the outside of the appliance not the outside of the vehicle.
(c)in any other vehicle, a refrigerating appliance or an appliance which does not expose a naked flame on the outside of the appliance and which is permanently attached to the vehicle and designed for the purpose of heating any part of the interior of the vehicle for the comfort of the driver and any passengers.
It also says "a refrigerating appliance or an appliance that does not expose a naked flame on the outside of the appliance"It doesn't matter as it stipulates 'heating' so that's what I'm talking about, it doesn't say MH/camper fridges can be used, either with or without a naked flame.
Not a clue it was over 30 years ago.So the idiot must have got prosecuted, how much did he get fined or was he jailed?
Was it not tested in court in respect of the above incident?![]()
I don't think the OP wants to make herself any colder!It also says "a refrigerating appliance or an appliance that does not expose a naked flame on the outside of the appliance"OK it mentions heating as well.
You’ll have to explain to me why that is! Coming from a school which has always maintained that in order to protect your engine you should allow the engine to idle long enough so that the oil has thinned and properly coated the cylinder walls/rings/bearings, before putting any strain on them, what is it xx about modern diesel engines that negates this? I’m well aware that modern oils act as a thinner oil at low temperatures, but as a thicker oil at high temperatures, but that doesn’t negate the premise high lighted above! Although not commonrail my 2.5TD engine has now done 300,000 and yet uses less oil than the original spec and have had nothing done to the engine in the 22 years I’ve owned it! In addition the idea that one shouldn’t let your modern engine just idle seems to fly in the face of what long distance lorry drivers routinely do! Someone please elucidate!I think you could but starting a modern diesel and leaving it to idle is the quickest way to clog your dpf and egr resulting in a 'limp home' expensive visit to your dealer.
BTW.![]()
Modern diesels do not get up to operating temperature on tickover you can leave them on tickover for half an hour and they still will not be up to operating temperature. This causes condensation in the bores and wrecks the CAT & DPF.You’ll have to explain to me why that is! Coming from a school which has always maintained that in order to protect your engine you should allow the engine to idle long enough so that the oil has thinned and properly coated the cylinder walls/rings/bearings, before putting any strain on them, what is it xx about modern diesel engines that negates this? I’m well aware that modern oils act as a thinner oil at low temperatures, but as a thicker oil at high temperatures, but that doesn’t negate the premise high lighted above! Although not commonrail my 2.5TD engine has now done 300,000 and yet uses less oil than the original spec and have had nothing done to the engine in the 22 years I’ve owned it! In addition the idea that one shouldn’t let your modern engine just idle seems to fly in the face of what long distance lorry drivers routinely do! Someone please elucidate!
I know a Motorhomer that this year didn’t switch the gas fridge off and was filling with lpg, explosion, side of van a right mess, she ended up in hospital, motorhome still not repaired as we speak.I thought the open flame of a fridge wasn’t allowed in filling stations.
My only query on your first sentence is, I was told a few years ago by a Fiat Professional mechanic that, mine & other modern vehicles, no longer have a direct temperature probe like the one on my old VW that sits in one of the waterways, but an air/engine sensor that sends a message to the ECU.Modern diesels do not get up to operating temperature on tickover you can leave them on tickover for half an hour and they still will not be up to operating temperature. This causes condensation in the bores and wrecks the CAT & DPF.
Should be driven off immediately after starting.
Not sure it was in Germany where she now lives.With all the talk of being 'tested in court' as there must have also been damage to the garage and surrounding area, is she being taken to court and sued.
If not, why not? (Just asking)![]()
Life presents plenty of risks, I'm content with my choices.That's might be ok until you come across a petrol spillage with fumes everywhere, at that point your probably going to wish you'd turned your gas off and weren't driving with a naked flame
That's why it's against the regs![]()
Yes, good point, when refuelling the fridge goes off.I thought the open flame of a fridge wasn’t allowed in filling stations.
A very risky strategy, remembering to turn off the fridge before you set off and may need fuel on you journey.Yes, good point, when refuelling the fridge goes off.
I don’t think they over size radiators these days Owen as they can save 50 pence by making the radiator only just big enough to cope.Can I say, for those that are not mechanically minded, Don't Panic!
While I agree with most of what has been said about engines idling and it is best if you do as I do, use it every week.
It is not essential that the minute your engine fires into life, you have to be off the grid like a racing driver.
It will happily set there idling for a few minutes while you clear the windscreen, check your lights etc as long as you take it for a decent run after.
In the olden days, we used to blank off part of the radiator so that it warmed up quicker!
(not sure if this acceptable with modern engines but if it gets really cold, that's what I'll be doing while keeping an eye on my temp. gauge)
I don’t think they over size radiators these days Owen as they can save 50 pence by making the radiator only just big enough to cope.![]()
Unfortunately it is a basic fridge and the setting is manual, there's no automatic option. It works fine on gas whilst moving, so it just gets left there.Just out of interest, why don't you use AES and let the fridge decide?, assuming your fridge has this setting.
No problem providing you have all the safety features that allow you to travel with the gas on - Crash sensing Regulator and either Anti-rupture hoses or bottles with Anti-rupture valves.Only time my gas gets turned off is for the tunnel
That was my understanding too, hence the ability to isolate the fridge, oven & hob with their individual valves to enable just the heating to be on with the required regulator & hose.As I read it the allowable use of gas in certain circumstances is ONLY for heating, not for a fridge ...
