thekindnesscoach
- Dec 6, 2022
- 5
- 1
- Fist Auto Apache
Can you start motorhome to warm engine while gas is turned on?
I’m sorry but are you reading these helpful replies or not?Thank you for your feedback, so are you also saying it is okay to turn in the engine whilst the gas is in? Thanks
Thanks, Kirsten.By no means an expert in H and S but I am assuming gas on but not lit ( tho maybe yes ) I would say no problem .. as we have inadvertently started engine and driven off before realising gas bottles were not turned off and had no issue . Can’t see why there would be a problem …but I bet someone else will have a different answer
If I am not driving, and turn of fridge in van would it be okay? It’s just to recharge battery & get condensation of front window.Fan flued heaters like the Truma Combi & Alde system can be driven with the gas on providing the gas system has the appropriate safety features, crash sensor & anti-rupture bottles/hoses. Other gas appliances should not be used when driving.
But modern diesel engines should be started and driven straight off and never left to idle from cold unless you want to risk thousands of pounds of damage.
OK but why risk wrecking the engine also to charge the battery unless you have a high power B2B it will take many hours to get a decent charge into the battery.If I am not driving, and turn of fridge in van would it be okay? It’s just to recharge battery & get condensation of front window.
Surely this depends on how old the motorhome is. I thought that all modern motorhomes have the 15 delay after ignition switch off, that allows enough time in the garage. Our 2014 model does and our previous 2011 model did.Yes, but remember to turn off the gas to the fridge pilot light if you visit a garage.
yes of course, but it’s worth mentioning so that there’s no risk of an incident.Surely this depends on how old the motorhome is. I thought that all modern motorhomes have the 15 delay after ignition switch off, that allows enough time in the garage. Our 2014 model does and ours previous 2011 model did.
Have you always done this? And if so, how many months/years? Also what can do you have? Is it a motor home? Thank meNo need to turn gas off or fridge off if stationary in my opinion.
Thank you for your feedback, so are you also saying it is okay to turn in the engine whilst the gas is in? ThanksCan I say, for those that are not mechanically minded, Don't Panic!
While I agree with most of what has been said about engines idling and it is best if you do as I do, use it every week.
It is not essential that the minute your engine fires into life, you have to be off the grid like a racing driver.
It will happily set there idling for a few minutes while you clear the windscreen, check your lights etc as long as you take it for a decent run after.
In the olden days, we used to blank off part of the radiator so that it warmed up quicker!
(not sure if this acceptable with modern engines but if it gets really cold, that's what I'll be doing while keeping an eye on my temp. gauge)
See earlier answer #3Thank you for your feedback, so are you also saying it is okay to turn in the engine whilst the gas is in? Thanks
I thought the open flame of a fridge wasn’t allowed in filling stations.We never turn the gas off and the fridge stays on gas all the time, moving or not. We have crash sensor, etc so I don't see why there would be an issue.
Unless your van is really old it will run on 12v while driving.We never turn the gas off and the fridge stays on gas all the time, moving or not. We have crash sensor, etc so I don't see why there would be an issue.
It is against the construction & use regulations to run anything with an open flame while driving.I thought the open flame of a fridge wasn’t allowed in filling stations.
Only on PVC's & very small CB's apart from a few concept type vehicles with the draw fridges. Still very much in the minority may see more when Lithium becomes a standard fit but that's a long way off.Newer vans manufacturers have tended to move away from installing fridges that need gas in favour of 12v compressor ones (run on 12v only)
We have a Dometic compressor fridge and it is superb, easily copes with hotter climates.
So all the issues around gas while on ferries or the van being serviced are removed.
Not if you have a gas hob, oven, boiler etc.Newer vans manufacturers have tended to move away from installing fridges that need gas in favour of 12v compressor ones (run on 12v only)
