Some suck it out if there’s an undertray to removeI'd be amazed if they left the oil to drain for an hour, more like five minutes for the main gush then plug back in.
Sounds like needless upselling to me.
There's always an undertray to remove but I've yet to find a garage than can refit it properlySome suck it out if there’s an undertray to remove
Smart car has no engine undertray bit also had no sump plug so had to be sucked out anyway - no way Jose so had to invest in a new sump with a drain plug fittedSome suck it out if there’s an undertray to remove
My comment re not wishing to give Broonfools the slightest bit of business, is based on a point of principal.I had a very pleasant purchase off them regarding spares department.
I need some plastic panel clips for the Rapido and only available from a dealer.
They had them in stock and even sent a picture to confirm they were correct.
The lady was most helpful and they arrived two days later.
Cheaper than another deal by some margin as well
no but i have been following the thread on comformatic gear box issues, it appears that the clutch (and brake fluid) need changing every couple of years BUT is often missed by those carrying out the service (for various reasons inc not having the right equipment to recallibrate, no mention in the service book etc)
my vehicle was first registered in 2018 and hasnt had it done, so as a preventative measure i am having it done.
i did ask Brownhills if that was something they could do, the service desk asked the mechanic but they didnt even receive an answer !
I can't think of any oil change I've done where 5 mins wasn't long enough to drain the oil.
But why such large discrepancies between Indy's and dealers?
Cheers,
Jock.
& many are 'scams as well.That's the problem with running a business...They have something called "Overheads".
Yes and any particulates are in the oil ?Exactly, I like the old oil to be hot as well so drains better
Having just done an oil change, the quoted costs for oil and filter are about right - dont forget they also have to dispose of the old oil - at cost.Yesterday I had my cam belt changed at Brownhills - cost £450.
I got a phone call part way through the 'job' (about 2 hours before I was notified it was complete), saying the mechanic had noticed a small oil leak, nothing of any concern and asked if I wanted a new oil change and filter. My first thought was, yes go ahead please as it's already being worked on, but I asked the price ...
Oil around £90 filter around £24 PLUS £90 labour ... I asked re labour charge and was told they charge an hour's labour as it takes an hour for the oil to drain ...
I couldn't work out why they wanted to charge me £90 for 'draining time' when it was stood there anyway while the cam belt was being changed, so I said no (I'm booking it in for other work soon, so will have it done then). I could understand being charged for the time it took to remove the filter and refill which may have been 20 mins or so, but to be told it was for draining down time seemed inappropriate.
When I went to collect my keys, two hours after the phone call, I discussed it very calmly with their service 'agent', with the discussion quite clearly being overheard by others, who could have intervened, but got a shrugged shoulder response.
I won't be using Brownhills again for any vehicle related issues!!!
You're entitled to your opinion. I think that as the motorhome was stood there, to charge 2 hours labour on top of the labour charge of having the cam belt replaced at the same time was 'unnecessary' ...Having just done an oil change, the quoted costs for oil and filter are about right - dont forget they also have to dispose of the old oil - at cost.
Just £90 for labour seems pretty good to me, as its not quite as easy as you think, lots of cleaning up when removing the old filter….
A Fiat professional garage would be charging you much more..
Stood on their ramp, which costs….You're entitled to your opinion. I think that as the motorhome was stood there, to charge 2 hours labour on top of the labour charge of having the cam belt replaced at the same time was 'unnecessary' ...
Which he is already paying for whilst the cambelt is being done, during which the oil would be draining away nicely.Stood on their ramp, which costs….
Cheers,
Jock.
Well if you run a business on that principle then thats great, but few do. Surely if a mechanic is doing the cab belt, another would be needed to do the oil change? And can a mechanic be reasonably expected to work on a vehicle whilst the oil is draining?Which he is already paying for whilst the cambelt is being done, during which the oil would be draining away nicely.
Cheers,
Jock.
You could have asked, while he is waiting for it to drain, could he pop around and cut the grass, being as you are paying for his time, you wouldn't want him working on someone else's vehicle for freeYesterday I had my cam belt changed at Brownhills - cost £450.
I did an oil change on our van yesterday in readiness for our big trip.
Oil - a little over 6 litres £34.00
Oil filter - genuine Borg & Beck £11.62
Getting out my tools for the job, doing the oil & filter change and putting my tools away, half an hour tops.
I know that they are a business and have to make a profit, but ......................
But but but...
How much is your hourly rate?
JJ
Don't you mean 'theft'...?When SAAB were still producing cars, I had the 2.2TDI engine in a 9-5. I wanted to do an oil change so went to SAAB for a new filter…….£70
No way, so noted that there were GM stamped on parts of the engine, so popped to Vauxhall and confirmed it was the same engine as used in their cars and a new oil filter……£12.
When I took out the old but original oil filter from the production line, it had exactly the same part number as my Vauxhall supplied one.
A £58 markup, now that’s just plain silly
Brilliant!You could have asked, while he is waiting for it to drain, could he pop around and cut the grass, being as you are paying for his time, you wouldn't want him working on someone else's vehicle for free
Those parts sound very cheap, I think the price would put me off.I did an oil change on our van yesterday in readiness for our big trip.
Yes i paid £80 for Selinia forward 0w-30 - 6litres, plus £30 for the filterThose parts sound very cheap, I think the price would put me off.
I wouldn't expect to pay that amount in a garage let alone doing it myself every 15k kms. I'd be bankruptYes i paid £80 for Selinia forward 0w-30 - 6litres, plus £30 for the filter
Sadly thats how much it is, couldnt get it any cheaper?I wouldn't expect to pay that amount in a garage let alone doing it myself every 15k kms. I'd be bankrupt
After my experiences with them I wouldn't let one of their "technicians' even clean my motorhome.Their reputation goes before them Dave, right back as far as 2005.............or further.
Personally, I wouldn't willingly by a pack of fuses from Broonfools.
Cheers,
Jock.
