When you load a bike up in the garage or rear rack, you've got to remember that it's behind the rear axle. So each kg of bike will take a little weight off the front axle and add a bit more than a kg to the rear. So if you're loading 150kg of bike, you'll need more than that 150kg spare on the rear.
Thanks. That's really interesting. I notice the support beam has Alko referenced on it. Does this mean you have an alko chassis as I am running on the FIAT light chassis? A real shame Watling Engineering closed. I spoke to Southdown Motorhomes about reinforcing the rear garage floor and they would only refer me to Watling (not being aware they had closed).Hi Andy, I don't know the exact specifics of your base vehicle other than it's probably the Fiat. I wondered if you could fit the same kit to go under the garage floor as I have. It's made by Sawiko and bolts directly to the Fiat chassis. I have added a couple of photos showing a before and after of it in place. I had mine fitted, but you can self fit if confident with spanners. It will give some peace of mind with a more comforting 250kg loading for the garage floor.View attachment 853735View attachment 853733
I have noticed that all these recommendations mostly deal with a combination of bikes and higher end motorhomes and presuming that the bikes are fairly heavy. Presently have a bespoke fixed carrier on the back of mine which copes with bikes up to 250cc approx and I am happy with that, and I do have air assistance and have no probs ar all at 3,500 However has nobody thought about a Rimor motorhome with the big garage that would at least cope with lightweight stuff, and it is affordable. From what I can see they are basic re equipment, not many bells a whistles.
So are they so bad that nobody owns one or wants one, maybe the use of a lot of wood re the shell and this puts people off buying, I have never seen a spec re the construction of these.
Hi Andy, I'm on the light chassis as well, but currently have a rating of 1850F axle, and 2240B axle total 4090kg.Thanks. That's really interesting. I notice the support beam has Alko referenced on it. Does this mean you have an alko chassis as I am running on the FIAT light chassis? A real shame Watling Engineering closed. I spoke to Southdown Motorhomes about reinforcing the rear garage floor and they would only refer me to Watling (not being aware they had closed).
Thanks Mike. I'm going to look into your solution for reinforcing the garage. My front axle has a limit of 1960 and 2240 on thd rear and like yours our fresh and cold water tanks are amidships. When we run out with the scooter loaded we carry a flippin' big 177lt storage box strapped down on one of the opposing bench seats so we can carry stuff that we can't fit in the garage (weight wise) with the scooter loaded. We get to site and the scooter comes out and the storage box goes in. The trouble is Burstner, in their manual, suggest the 150kg limit should be an excption but don't say for how long. So what is their recommended maximim?....no idea, and occasionally we have run the garage at 165-170kg and just a little nervous about this. Are Burstner being overly cautious or are we being overly irresponsible by exceeding the max garage weight, even if it is no more than 20kg?Hi Andy, I'm on the light chassis as well, but currently have a rating of 1850F axle, and 2240B axle total 4090kg.
The difficulty, is getting that load froward enough to use all the front axle, but our cold and waste water tanks are midship, so that helps quite a lot.
Mike.
We have an Etrusco i7400 a class we carry a Honda 125 scooter 116kg in the bag and the garage is height adjustable. We recently bought a trailer which is great but you cannot reverse with it, but saves your garage space. In Italy they all had electric mopeds in their vans much lighter !Hi
What are the best makes to search to find a motorhome that has a garage store at the rear to transport a motorbike when touring
Burstner 690G Plus Honda Grom at 100kg and still under 3500kgHi
I can only suggest having a look underneath at the current rails and take a view on it. I also screwed some angle bracket the full width of dropped down section of the garage box. This was to help absorb the point loading of the centre stand as our scooter travels better that way.Thanks Mike. I'm going to look into your solution for reinforcing the garage. My front axle has a limit of 1960 and 2240 on thd rear and like yours our fresh and cold water tanks are amidships. When we run out with the scooter loaded we carry a flippin' big 177lt storage box strapped down on one of the opposing bench seats so we can carry stuff that we can't fit in the garage (weight wise) with the scooter loaded. We get to site and the scooter comes out and the storage box goes in. The trouble is Burstner, in their manual, suggest the 150kg limit should be an excption but don't say for how long. So what is their recommended maximim?....no idea, and occasionally we have run the garage at 165-170kg and just a little nervous about this. Are Burstner being overly cautious or are we being overly irresponsible by exceeding the max garage weight, even if it is no more than 20kg?
Here you go, these save a load of hassle, I have them on our wave.Another vote for carthago. Got a C Tourer 150 QB and a BMW g310r that fits in the garage with the mirrors removed. The van is 4250 kg. We weighed it empty and had 600kg available with 600kg available on the rear axel. I believe the garage will take 350kg. Wouldn't travel with a full water tank with the bike on board though, but carthago has a nice feature that you can empty the tank leaving 20 litres in there, specially for travel.
We were looking at the duke 390, but the BMW is better for a pillion. It is also surprising good with a pillion, zipping around at 50 mph no problem
We have a Knaus Sky Ti 650MG and when we bought it new in 2016 we had the garage load upgraded from 150Kg to 250 kg which also improves the rear axle loading; it has stronger springs and a reinforced rear subframe. I've had several bikes in the garage over the years (Yamaha MT-03, Kawasaki Z250, Honda Grom) but I've now settled on a Honda CB300R which we've had since 2018. The Honda is 143Kg wet. It's significantly lighter (and slightly smaller) than the KTM 390 Duke and BMW G310R. It has more than enough power and torque to haul me and my wife about on holidays and with a tank bag and Ventura luggage on the back it's a great shopping trolley too. Sits comfortably at 70MPH all day, so quite safe on motorways, and being a Honda (albeit one built in Thailand) it's super reliable and cgheap to run and insure. I have a Sealey Bike Chock in the garage mounted on a wooden "plate" so it can be removed if required. Van is plated at 3500Kg and we're OK on payload most of the time. Had it on a weighbridge recently though before going away fully loaded with the bike and a load of other stuff in the back and we were slighly over (but still well within the premitted axle weights) so I might up-plate. My experience suggests 3500Kg is tight if you want a bike bigger than a Grom but it can work. In summary, the Honda CB300R is the best "van bike" I've found so far by a mile in terms of size, weight, performance and comfort and I only need to remove the bar ends and mirrors to get it in the van garage - a 2 minute job. Finally, a word of caution re: the Honda Grom. As much as I loved my Grom, they just don't work on anything bigger than local back roads or for town / city commuting. They are a liability on more open A & B roads and even solo you'll have lorries up your backside on the slightest uphill incline. Makes you feel very vulnerable. Truly hopeless two up.Hi
We had a fiat ducato 6.3 metre van converted to a campervan to take our motorbike. We take our Truimph Tiger 850 or Suzuki GT 550 . Had an electric winch and ramp fitted . Make Sawiko.
I’ve got a Carthago eline for my bike but you can get the same size bike (KTM Duke 890) in a c line. View attachment 85
My previous van was on an Iveco chassis with twin rear wheels and a 3.7 ton rear axle. Carried a 300cc Honda scooter on a custom made rack.Hi
I've got a Knaus 650MEG Sun Ti (3850kg) with a garage big enough for a motorbike but I think the weight capacity is 150kgs. I don't really want a scooter or 125cc and so far the lightest bike I would consider is a Fantic Caballero. The 500cc one is 150kgs which would mean I couldn't have anything else in the garage, the 250cc version is 135kgs. I still can't decide whether to just buy a bigger bike that I would prefer and get a trailer.
MCL manufactured bespoke motor homes in North Wales up until about 2014. They were built on either Mercedes or MAN lorry chassis. They all have large garages in the stern and some, particularly the ones built on the 10 tonne MAN chassis, had an overhead extending and retracting frame with a winch designed to pick up a Harley Davidson and stow it in its fixed stowage on the deck of the garage. They are pretty rare beasts so you might have difficulty in finding one and of course you will need a HGV licence.Hi
Really? How can I check? That would be a game changer!Might be worth checking as some come out the factory with garage allowance of 250kg
