My 350 scooter must be a bit taller than your KTM, I have 8mm clearance with the mirrors offI’ve got a Carthago eline for my bike but you can get the same size bike (KTM Duke 890) in a c line. View attachment 853357
Yes. There are vans that'll take a 200kg bike. But many won't.I’ve got a Carthago eline for my bike but you can get the same size bike (KTM Duke 890) in a c line. View attachment 853357
I'm not out for an argument, the OP asked which vans can take a motorbike, I've told her of a couple that can.Yes. There are vans that'll take a 200kg bike. But many won't.
There are a few 6.4m panel vans with "race van" style layouts. The bed is high up and lengthways over the garage.
Agree. I'm just pointing out that just because a bike will fit, it doesn't mean you'll be able to carry it. Floor loads in garages are often limited to 150kg. And rear axle loads are often an issue.I'm not out for an argument, the OP asked which vans can take a motorbike, I've told her of a couple that can.
Both Carthago's I mentioned are capable of carrying motorbikes.Agree. I'm just pointing out that just because a bike will fit, it doesn't mean you'll be able to carry it. Floor loads in garages are often limited to 150kg. And rear axle loads are often an issue.
Good idea but potentially could have a small impact on your travels, especially in Germany where you have to stay in the truck lane with a reduced speed limit, the Polizei don’t like it if you stray outIt may be easier to fit a tow bar and put the bike on a trailer.
No limit on size or weight, you could even carry two bikes!
These trailers look good
With a trailer you are normally allowed in lane one and two on the autobahn.Good idea but potentially could have a small impact on your travels, especially in Germany where you have to stay in the truck lane with a reduced speed limit, the Polizei don’t like it if you stray out
Lane one only on a two lane autobahn like the A61 Koblenz for exampleWith a trailer you are normally allowed in lane one and two on the autobahn.
I don't know about you, but I normally set my max speed to 65mph which means I can overtake the freight.
I spend all my time in lanes one and two anyway.
My van is 3.850kg, but in Europe looks exactly like the 3500kg model.
I'm not supposed to be in lane 3, although I'd defy any cop to read the weight plate at 65mph
In 25,000 miles of travel I doubt I've done even a full mile in lane 3.
Its an answer if you don't have a C1 or above but the problems are limitations on stays, lower speed limits ( except France) and theft issues.It may be easier to fit a tow bar and put the bike on a trailer.
Now tell me again why you bought KTM's ?We carried first a 690Duke then a 790Duke in our 4 Ton Mizar, had to slightly modify a bit of the garage and move mirrors to get it in. Was regularly taken over the local weighbridge and we were always within limits
We have a rollerteam sport parked next to us in storage, he uses it for motocross, i think.
We niw have a 350 motorhome with an easylifter and a different but very similar weight bike.
Will depend largely on your budget and the size of MH you want. Generally (although not always) the bigger and/or more expensive you go, the better the garage capacity will be. The key dimension to focus on in my experience is the clear height. If you have 1.20m or more you will be able to fit a wide range of bikes in the garage.Hi
What are the best makes to search to find a motorhome that has a garage store at the rear to transport a motorbike when touring
Have been tempted by a 390 Duke a few times but struggled to find a wet weight for it - googling seems to say anywhere between 153kg and 175kg. You haven't weighed yours by any chance have you?Another option is a rack. This isn't tow bar mounted, I goes onto the chassis rails each side. The Duke 390 is 149kg dry so right on the rack limit. The rear axle is still well under it's maximum capacity because the van has a short overhang
Garage height is a limiting factor, I would have preferred an adventure style bike like the vstrom but they are just a bit too tall.If you have 1.20m or more you will be able to fit a wide range of bikes in the garage.
Agreed....all adventure style bikes have higher bars...but surprisingly lots of sports or naked bikes and even lots of scooters are very similar in height if you are happy to change/fold or remove the mirrors to load up.Garage height is a limiting factor, I would have preferred an adventure style bike like the vstrom but they are just a bit too tall.
No, I suppose it depends on how much petrol is in it. Mine has also got rear rack and shad pannier brackets. Can't believe it was only £3099 new in 2017 fantastic bike, I've got the new Hornet 750 but I'm always excited to be jumping on the Duke just bought some meaty tyres for it so I can rip the camp site upHave been tempted by a 390 Duke a few times but struggled to find a wet weight for it - googling seems to say anywhere between 153kg and 175kg. You haven't weighed yours by any chance have you?
