Battery charging
Costa Blanca
Rapido 8086df
Hi, first night last night off grid, my battery is down to 71%. I've switched the combi inverter off. Does it need to been on to charge batteries. Thanks, it's still a learning curve for us.
I think the inverter will be powering any 230v appliances you have connected and therefore draining the battery.
Charging is done by solar, electric hook up or driving.
The inverter is still drain the battery if turned on and not powering anything, so it's worth turning off if not in use.
As Figaro said, most inverters will consume some power on standby even if you don't have anything connected to the 240v so if you're 'off grid' and not using the 240 then switching the inverter off when not in use will help conserve the batteries.
There are also 'Inverter Chargers' which might be behind the question. These are 'all in one' units that act both as an inverter and as a charger. However, they only act as a charger when you connect them to shore power. Charging from solar or from a DC-DC (aka B2B) charger will be independent of this.
Short answer:
Turning inverter off when not using 240v is fine. (y)
Depends how big your battery (s) is/are we can easily use 10 to 15% overnight out of 500a if you only have 100a then no cause for worry.
If you not using any 230v appliances turn inverter off as there is small drain. This time of year you will have heating on, tv, lights etc so normal I would think.
Keep in mind, It wontcharge your batteries if you are off grid.
You need to be on site plugged in with ehu for the battery charger to work.
When off grid a b2b when engine running or solar does the charging if you have them
Always turn the inverter off when not using it as just sitting there it will draw 1 to 1.5 amps that's up to 36 ah over 24 hours.
We have been away 2 nights our batteries are at 73% so used 131 ah that's low for us normally use more than that in the summer.
Thanks for replies, the sun is out now. Will look in a bit if any charge is going in
If you're in the UK solar is unlikely to do very much in December as the sun is so low in the sky.
But you should see some charge going in to confirm it's working 👍
Thanks, we are in the Mar Menor, still on 72% with the inverter off and only using gas for fridge and hot water.
But as I said SOC varies depending on the amount of battery ah you have, not sure how big the OP Mart 63 has to know if it's excessive.
Depends on the inverter though.
My 2,000 watt inverter only draws 0.1 amps or 2.4 amps per 24 hours on standby according to the Victron Shunt.
Just took this screenshot
That's very low mine in standby is 1.4 amps, in AES mode 0.9 - 1 amps, not tried Search mode as I know it may not turn on with light loads but supposed to be 0.4 amp. Victron 3000va Multiplus 2.
Which make of Combi inverter do you have? Some will allow you to set a lower draw when on standby, but I tend not to use those features that automatically detect when a 240v device is turned on, and just switch it to "Charger Only" when we are not using 240v kit and are on EHU, and off when we are off EHU.
As others have said the batteries will charge from Solar, and the engine alternator if the Combi is off (its independant), then when you have EHU the Combi's charger will come on in addition to your solar.
That's very low mine in standby is 1.4 amps, in AES mode 0.9 - 1 amps, not tried Search mode as I now it may not turn on with light loads but supposed to be 0.4 amp. Victron 3000va Multiplus 2.
Yes I was surprised how low it is but my shunt confirms the draw is only 0.1 amps.
That is with the inverter turned on on its on/off switch and on standby on the remote display.
I haven't actually turned the inverter off on its on/off switch since fitting it nearly 12 months ago.
In winter my solar covers the drain easily as it is so low.
It's gone up 1%, another question. Will charging a phone us much power. Thanks
It's a Mastervolt system
Not much my phone charging from a USB socket at 2.9 amps takes 1.2 amps from the 12v supply, if you are using a mains charger it will be a tiny bit more plus the inverter overhead that could be another couple of amps. So best not to use a mains charger.
I didn't know Rapido used Mastervolt, I take it you have a fairly big Lithium system.
What actual draw ?
If your shunt is showing a draw of 0.1a and you have 3a coming in from solar the actual draw is 2.9a so turn your solar charger off and see what the actual draw is without any charge coming in.
The 0.1 amp inverter standby draw readings were at night so no solar charge to skew the readings.
If I have the inverter on and the remote on but am not using any 240v items from the inverter, so effectively standby, the draw is 1.2 amps.
Having the inverter turned on but the remote in standby reduces the standby drain to 0.1 amps.
On mine the remote turns the inverter on/off so no draw at all when off?
