Don Quixote
- Jul 29, 2012
- 2,966
- 5,264
- VW T6 Campervan
- Not long enough, but a little common sense helps..........
Since installing the Sterling Battery to Battery charger, along with a , I have not had cause to run our Honda Generator at all. This year at some rallies the Funster band have been using power straight from our two 110 Banner batteries through the inverter. Should the band get too many encores (a common occurrence) I know all I have to do is run my engine a little while and the batteries are back to 85/90% very quicklyWho needs a genny, who needs the sun. You just need a B2B- for me its perfect.
No. It does not work that way. Cruise controls the speed of the wheels (or rather the output from the gearbox) not the speed of the engine.Could you use cruise control and increase the tick over while charging ?
That sounds more like a hand throttle lever rather than cruise. Similar to putting a brick on the accelerator pedal.Oh must be different on trucks then, if low on air you can put it on cruise to build up air while strapping your load or other jobs.
LOL how can it control your cruising speed, when your stopped
Don't forget that you can buy Alternator to Battery chargers and you can fit 220VAC alternator which do use "hand throttles" AKA Cruise control to some
Eddie
I said that 13.8v is float? I did not say that MH charging systems hold 14.2v for a long period of time - I said for a period of time. Mine holds at 14.2v for around two hours IIRC. The vehicle alternator is (in many/most MHs and caravans) connected directly to both start and leisure batteries as long as the engine is running. Its output is preset at 14.2+V. It follows therefore that both batteries will be charging at this voltage for varying and quite lengthy periods. The charge current flowing at this time will be nowhere near even 10A after the first few minutes. Which is why it is almost impossible to fully charge a leisure battery using the vehicle engine and why a B2B charger needs to be (and is) a pretty clever device that raises the charge voltage well above 14.2v (probably in excess of 18v) and monitors the charge current (amongst other parameters) to safely "fast charge" the leisure battery.Firstly 13.8 is FLOAT charge...... secondly all vehicle alternators charge at voltage of at least 14.2 is correct HOWEVER most charging systems fitted in motorhome these days DO NOT all 14.2 volts for a long period of time and step the voltage back to FLOAT charge of 13.8. If the voltage was allowed to stay at 14.2 or better the amps would be in the high 25/30/40 amps - if this was the case your batteries would charge in no time!!!!! BUT because it is stepped back this is why does it take 8+ hours of driving to charge the batteries.......
As I have stated already this is a "gray area that many do not understand" - why would Mr Sterling make the battery to battery charger if the system fitted in motorhome or boats for that matter have such a good system fitted already ??? - CBE or any other system fitted will only charge your batteries to 80% period. They DO NOT FULLY charge your batteries. it takes 2/3 days of charging with NO LOAD to fully charge batteries.
MH manufacturers connect everything together with wire no thicker than a boot lace. And always have. To compound the error they're now fitting charge / control panels with multi-plugs designed for boot laces............... whereas motorhome manufacturers tend to locate the leisure battery(s) where there is a space and connect them together with a bit of wire no thicker than a boot lace!
Not sure your comment is correct for all motorhomes. IIRC according to the manual the current from my alternator goes through my Schaudt Electrobloc and its voltage and size is changed depending upon the type of battery and its state. It certainly seems to get above 14.2V at the battery, but that must obviously be at the expense of current. For how long it holds at that state will depend upon the type of battery, because Gel batteries have a different charging regime to lead acid, all of which is controlled by the Electrobloc.I said that 13.8v is float? I did not say that MH charging systems hold 14.2v for a long period of time - I said for a period of time. Mine holds at 14.2v for around two hours IIRC. The vehicle alternator is (in many/most MHs and caravans) connected directly to both start and leisure batteries as long as the engine is running. Its output is preset at 14.2+V. It follows therefore that both batteries will be charging at this voltage for varying and quite lengthy periods. The charge current flowing at this time will be nowhere near even 10A after the first few minutes. Which is why it is almost impossible to fully charge a leisure battery using the vehicle engine and why a B2B charger needs to be (and is) a pretty clever device that raises the charge voltage well above 14.2v (probably in excess of 18v) and monitors the charge current (amongst other parameters) to safely "fast charge" the leisure battery.
Eddie - will you be at Lincoln, because I would like to discuss with you the advantage (or not) and cost of me getting a B2B system fitted.
Has anybody seen the article on batteries/charging by Alan of A&Ncaravan services, the hymer electrobloc specialists, he doesn't rate B2B chargers or solar, instead recommending a generator? He also raves about Bosch S5 batteries as the bees knees.
Paul.
Paul, I did and it's a minefield, however I'm convinced the way ahead is B2B regardless of what he has written because if the boating fraternity swear by them and many MH owners have them fitted and are very pleased I'm sure I will. I get home around the 14 September and when I have got hold of some + /- cable I will fit it and then post on here my findings. All being well I will have a Honda 10i for sale that I have dragged around for past 2 years and used a handful of times.........Hi John. I,m crap at links, just google the firm and click on batteries.
Paul.
Confused . Com ?
When a battery is fully charged what voltage should it read when tested ?
I have two 110 battery's that have been on charge for several days when I unplug the EHU they read 13.2 but drops to 12.6 in about 10 minutes under no load is this normal?
I also have a solar panel fitted by the dealer as part of the sale but no paperwork how do I test the output we allways seem to struggle to keep the batteries above 12v
Had that on my minibus. Fine in the summer but not in the winter. In winter I had to carry a spare battery to jump start the beast.Am following this as it's interesting. One thing I have always wondered, on trucks I drive they hang a battery pack on the chassis behind the cab out in the open. Why do they not have similar on motorhomes . They make beany boxes to use space under the vans, why not have a cage for battery's under the van instead of sticking a battery under the drivers seat etc.
EddieHi Peter, No sorry we don't do the Lincoln show, we tried it a couple of times and it doesn't work for us.
Please also bear in mind that if your motorhome has an Electrobloc with an ammeter that fitting a B2B will "confuse" the system. The ammeter counts amps in and amps out and tells you what is happening.
The B2B has to be connected directly to the batteries and will be charging the batteries, without the ammeter knowing.
That's not a problem until you discharge the batteries when off hook up and the system thinks that you've used more than you have put in and starts to panic, erroneously!
The only solution to this is to fit a separate battery computer that will keep tabs on "everything" in, and out. We use the Victron unit which will handle 500Amps on the shunt so will allow for inverter discharge to me measured accurately. The Electroblok couldn't handle these levels of charge/discharge so have to be by-passed.
This is in no way any reflection on the equipment, but as I have said before, the average motorhome is designed for the average user to do "average things" So moderate use, normally on hook up when possible, mainy relatively short runs at weekends with a couple of longer runs/trips a year. Based on this, water tanks, grey and loo, battery capacity and charging regimes all tend to do the job, but can be enhanced/improved with specialist attention or equipment.
I also have solar panels regulated by a Schaudt regulator via the electrobloc and again, IIRC, the regime applied is supposed to be the same.
Having said all that the wire between the alternator and the Electrobloc seems pretty thin on my motorhome, so it is not going to move large amounts of energy about! Although the wire from the Electrobloc to the adjacent battery is a lot thicker, and certainly a lot thicker than a shoe lace! But still nowhere near the size of the starter lead I used to connect the second leisure battery to the first with.
