Bad design in my opinion (2 Viewers)
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
Our new carthago has what I think is a silly design in where the grey waste pipe is located it's about 3 inches off the floor to the rear of the o/s/r wheel I am sure someone must have smashed this of their carthago
I decided to move mine and mine now exits just in front of the n/s/r wheel and is about 2 inches higher than it was so hopefully won't get caught
Feb 24, 2013
13,083
101,456
Bolsover, Derbyshire
Hymer S800
not long enough
isn't it bonkers, yet again, when the user has to sort out design balls ups :mad: as ever designed by non users o_O
from your photos I cant easily see how you have gained the height off the ground, they both appear to be fixed to the chassis which is the limiting factor,
Hope the increased outlet height doesn't affect the emptying rate (y)
R
Robert Clark
The other bad design on the waste system is that the handle has a nasty habit of lifting up off the valve, which is a nightmare to fix
Best to apply downward pressure when turning it
Zepp
1,673
3,260
Roaming
7 Years
I also lifted mine and fitted a tap so I dont have to go into the locker inside to open the wasre valve
Quite a few people have had the valve / tap break inside so be gentle with it LOL
(Robert beat me to it )
Lanerboy
Lanerboy
1,363
2,206
midlands
I must admit the handle feels very stiff to turn almost notchy I might fit an external tap like Zepp has then just leave the one in the locker open
Gellyneck
9,237
18,255
More than toes wet now!
Great adjustment!
Now when the grey waste is pouring out as you're fleeing down the road the n/s/r wheel / tyre will be able to spray it about all over the place instead of it just landing on the road!:whistle::imoutahere:
Zepp
1,673
3,260
Roaming
7 Years
I fitted one like this not sure where I got it from I think it was ebay for £5
R
Robert Clark
A mod to consider is making the external valve motorised, then you could empty out without leaving the comfort of your little palace
We had a downward facing camera fitted by our outlet pipe so we could see where we were positioned- a great feature
Lanerboy
Lanerboy
1,363
2,206
midlands
I have fixed the holding bracket higher up on the chassis so it does not have as much fall, the fall now is only slightly more than level but this will not matter as the whole pipe is below the lowest point of the grey tank plus I have E&P jacks so can use these if required.
Also it will not catch on the floor when driving up a step shallow slope like the bottom of my driveway and now its in front of the rear wheels I will not accidentally break it off if I was to reverse up to a kerb or similar object.
LB
May 23, 2008
2,481
3,483
Near Durham City
Carthago
Since 1984
I've had all the issues discussed. No doubt more of my breakages/replacements will follow with other owners.
My personal opinion is still the same Carthago + quality = 0
