Well it does seem like the full cast of the Lion King are using my garden as a playground so you never know..Still recon lion poo but if struggling tiger will do![]()
Depends on Age/Make of the Vehicle, some used the ABS Sensor on a wheel, others use a sensor on the Gearbox... but all modern once tend to be fly by wire...Update!
So, this morning the little f******** have done the christmas lights on the tree in the front garden.
Operation Exterminate in full flow,
Cctv , chemicals, traps, …. phase 2 … troops, electric fences etc,
Cant access lion poo but I fully expect one of them to come along in a minute,
We are not even rural …
In laymans terms, anyone tell me how the mileage registers on the dashboard, is it an electrical connection to a wheel? Never thought about it before…
Mines 2016 peugeot Boxer pvc, sorry should have said that,Depends on Age/Make of the Vehicle, some used the ABS Sensor on a wheel, others use a sensor on the Gearbox... but all modern once tend to be fly by wire...
There will be 2 set of wires on the front wheels probably, ABS sensor and Brake Pad Wear Sensor, unless it's the Older metal clip on Pad Wear...Mines 2016 peugeot Boxer pvc, sorry should have said that,
I’ll get a photo of a chewed wire that I think may be it
All towbar electrics are mangled…![]()
ThanksThere will be 2 set of wires on the front wheels probably, ABS sensor and Brake Pad Wear Sensor, unless it's the Older metal clip on Pad Wear...
Now you are making me think! My MOT garage reported broken Brake Pad Wear Sensor and sometimes in my Ring camera footage I can see what could be a mouse or rat running across near the van but always at night so not very clear.Thanks
Christ I havent even checked the front of the van![]()
Completely agree.I reckon you have a mouse infestation somewhere on your van they will cause a lot of damage? You need to look for a nest of them in the van somewhere![]()
We have a hedgehog that walks across our drive and under the car, it brings the security light on and scares AnnNow you are making me think! My MOT garage reported broken Brake Pad Wear Sensor and sometimes in my Ring camera footage I can see what could be a mouse or rat running across near the van but always at night so not very clear.
I agree, but be prepared for more damage before you find out.Get a cheap trail camera with infra red night vision and put it under the van. That way you can verify exactly who or what the culprit is. Then you can use the correct 'treatment'
Good suggestion .thank you ...I reckon you have a mouse infestation somewhere on your van they will cause a lot of damage? You need to look for a nest of them in the van somewhere![]()
Good shout, will have to think as I need it everydayMove the van![]()
If you have largish size holes appearing in your garden, it could be foxes.Well it does seem like the full cast of the Lion King are using my garden as a playground so you never know..
Tip......We have a hedgehog that walks across our drive and under the car, it brings the security light on and scares Ann![]()
That's cruel,the hedgehog needs the light to see where it's going.Tip......
Try turning the security light off so that she can't see the hedgehog.
Ya furgot the banjo! Gotta have banjo music in the background!Shotgun and deckchair, is a permanent solution
