OldAgeTravellers
I quite agree @JJ that is how it should be unless you want to exploit the facilities of the Schaudt Elektroblock and panel then you have to jump through the hoops it puts up. Connecting straight to the batteries will charge the batteries but not show the charge from the panels without adding another meter and could confuse the panel so it thinks the batteries are empty when they are not.
I would have preferred to use the controller that Andy favours as I did on my last van but it could not talk to the EBL so I had to pay twice as much for the Votronic but that does have tha advantage that it will use the +S terminal of the AES fridge so that it will automatically switch the fridge to Solar if there is excess charge from the panels.
Unfortunately this new to me Hymer is quite a learning curve a bit like modern cars which are becoming so complex that it is increasingly more difficult to work on them. Today's "grease monkeys" wear rubber gloves and fix everything with a laptop which tells them which board to swap. Was it better when a large hammer and a can of grease fixed everything? Simpler perhaps.
Steve
Steve
