Anything that may help save a life has got to be good. We’ve had quite a lot of cyclists killed by HGV lorries in recent years locally and from the news reports none seemed to be the fault of the cyclist. I accept I personally would not have liked to have displayed them on our old van but the law is the law, we choose to disregard it and have to suffer any consequence. Spain have introduced new laws for similar reasons & here in the UK the coming new laws will be the larger the size indicates whose responsible, unless proven otherwise, so we’re all going down similar routes it seems.
Or educate the drivers.From the Ministry of Transport:
Pedal cyclists There were 100 pedal cyclist fatalities on the roads in 2019, very similar to the level seen since 2009. Any changes since that point are most likely a result of natural variation and cannot be attributed to underlying causes.
The number of pedal cyclists killed or seriously injured in Great Britain has increased by 8% between 2009 (4,098) to 2019 (4,433) (using the series adjusted for changes in severity reporting). This is partly explained by an increase in pedal cyclist traffic in Great Britain of 16% from 2009 to 2019 (3.0 to 3.5 billion vehicle miles). Overall pedal cyclist casualties decreased by 4% between 2018 and 2019.
How many lives or injuries would have been prevented by stickers on vehicles?
Would make more sense to prosecute (if that were possible) cyclists that place themselves alongside vehicles at lights and junctions.
.....or insist that cyclists wear hi-viz vests and helmets, stop using the roads as 'training' - going flat out regardless of conditions, putting themselves and others in danger...................just slow down !
So very frenchSome websites say visitors need then others say they don't. But what is common is they are only required in urban areas.
The French tend to assume all Motorhomes are 3500kg so I'm not too worried I won't be fitting them to my 4500kg van.
Better cyclepaths would definitely help, as would requiring registration plates for bicycles and banning earphones for all road users including pedestrians.Or educate the drivers.
Germany, Denmark, Netherlands, Belgium and France all have miles cycled per head of population way ahead of the UK.
Yet, with the exception of Germany (at under 400), all have others have cycle fatalities in double figures per year.
Even if you account for greater population, more crowded roads, cycling provision that is 30 years behind neighbouring countries and because of that there are less cyclists in the UK, the UK figures are embarrassingly high.
this joker has turned over in the region of £2000 I am not sure he is as daft as you portray (wish I'd thought of it )The original ones were truck or bus - of which the bus one was to be used on motorhomes. Some joker on eBay seems to have produced his own version with a motorhome on it.
<Broken link removed>
He also put his price up the 6th July.this joker has turned over in the region of £2000 I am not sure he is as daft as you portray (wish I'd thought of it )![]()
So If you're in a French town with your stickers in the correct place, turn right and mash a cyclist, you would expect to be exonerated?If you have a warning sign and whoever ignores that warning sign, then you're off the hook if they mash themselves while undertaking you. They had been warned.
Same goes for any other warning sign.
If you see a sign that says 'Warning Uneven Surface' and fall over, would you expect to be able to get any compensation?So If you're in a French town with your stickers in the correct place, turn right and mash a cyclist, you would expect to be exonerated?
So given my scenario, do you think that having the sticker fitted would make any difference to what would happen next?If you see a sign that says 'Warning Uneven Surface' and fall over, would you expect to be able to get any compensation?
Of course I don't THINK ITS OK to mash a cyclist - however, if you go around ignoring warning signs then you should be prepared for bad things to happen to you.
How could you be 'more aware' of something you can't see? Do you now always assume there is some pillock sitting in your blind spot and never turn left or right ?We were advised by the RHA that there has been a new directive introduced in the highway code which basically states that if a cyclist or pedestrian are involved in an accident with a hgv the automatic conclusion should be that it is the hgv drivers fault as he should be more aware of the hazards posed by cyclists and pedestrians, as he is a professional driver? And they wonder why there is a driver shortage?
I can't find the RHA memo but the press reported on it too:
"Car and lorry drivers will automatically face the blame for accidents with cyclists due to sweeping changes planned for the Highway Code, campaigners have claimed.
The Government is rewriting the official guide to give cyclists more protection on the road"
What a load of.......
I'm not even going to bother...So given my scenario, do you think that having the sticker fitted would make any difference to what would happen next?
I'm not having a go, I'm just trying to explore the angle of what difference having a sticker fitted would make?I'm not even going to bother...
If a sticker reduces the risk of having to attend an inquest, I'd choose a sticker every time Its all about reducing the risk not illuminating it, as there is no remedy for stupid, and if the sticker is there you have given the naïve the opportunity to react and stupid the opportunity to ignoreI'm not having a go, I'm just trying to explore the angle of what difference having a sticker fitted would make?
I regularly drive trucks, and ride bicycles, so can appreciate it from both angles and there are sure are bad apples in both barrels . I would agree wholeheartedly that there are too many collisions involving cyclists and its usually the cyclist that comes off worse but it doesnt seem to stop the reckless element among them from ignoring the basic rules of the road.
So do you think they would take any notice of the sticker? and if you were making a legal turn and something happened would having the sticker fitted make any difference to your liability?
According to the French regulations that I’ve seen 360° cameras make no difference. You still need the stickers.A question: Angles Mortes stickers are to notify pedestrians and cyclists of a vehicles blind spot. I have a 360 camera system and so, in effect, no blind spots. Will I still need these useless stickers?
But the question remains, will those who ignore the presence of a hulking great truck gain anything from a sticker? Will it even save one life? Me I doubt it but I will be watching the cycling casualty figures for France and London with great interest.If a sticker reduces the risk of having to attend an inquest, I'd choose a sticker every time Its all about reducing the risk not illuminating it, as there is no remedy for stupid, and if the sticker is there you have given the naïve the opportunity to react and stupid the opportunity to ignore
It just another aid to reduce risks much like a reversing camera and lots of drivers seem happy to attach these
This has been true in many countries for years.We were advised by the RHA that there has been a new directive introduced in the highway code which basically states that if a cyclist or pedestrian are involved in an accident with a hgv the automatic conclusion should be that it is the hgv drivers fault as he should be more aware of the hazards posed by cyclists and pedestrians, as he is a professional driver? And they wonder why there is a driver shortage?
I thought the same as you so had a look at Wikipedia :-Maybe there are 2 threads running, but I posted asking if anyone knows of the definition of 'urban' in this law.
Does it mean anywhere that town/village 50/30kph limits apply?
If not, what is the definition?
Maybe France Residents can explain.
Geoff
