stewartwebr
- Jun 6, 2010
- 1,541
- 5,529
- Morelo Empire Liner
- 36 years and 16 motorhomes
I agree but the Alde load master gives more flexibility in that it is only controlling and limiting the power directed at the Alde. It depends if your Motorhome is wired in such a way that it has essential and non essential distribution boards in relation to inverter supplies. Morelo do wire this way which makes it easier in that I can select the total load limit on the inverter controller. This limits the supply fed to the essential supplies and any surplus power required is fed from the synchronised inverter. So if I set the current limit at 10 amps and the essential supplies require 15 amps the inverter makes up the additional 5amps. However, given you don’t want to be feeding non essential supplies from batteries they are not contained within the inverter power supply so are not limited or deficit controlled, so the addition of the Alde current controller gives greater flexibility in relation to power limiting a non essential supply.This function is provided by some Hab controllers, eg the Sargent EC600 has a secectable AC Current Limiter (you choose the limit) which switches out the heating elements as you describe.
