As the title says, anyone got these fitted and what’s the best lubricant? Found this which I presume is the correct stuff but wanted a second opinion.
No!!!!!!!!!WD 40?
I have graphite for the doors at home, and have used it, but not sure if it’s the correct stuff- having read ABUS web site below? Hence the confusion.Microfine Graphite Powder, available on Amazon.
Best get some of that then, might order some myself.I have graphite for the doors at home, and have used it, but not sure if it’s the correct stuff- having read ABUS web site below? Hence the confusion.
Never use WD40 oil on a lock!WD 40?
I use PTFE spray on ALL locksAs the title says, anyone got these fitted and what’s the best lubricant? Found this which I presume is the correct stuff but wanted a second opinion.
Ive used WD 40 on countless padlocks and door locks and they have always worked slickly?Never use WD40 oil on a lock!
Unless the intention is to gum up the lock and knacker it on a permanent basis !
If you have done this, then acetone will remove WD40, if you can find a way of getting it into the lock.
(We soaked a dozen 'keyed alike' WD40'ed padlocks in a washing up bowl of Acetone, but they were never the same, we had to replace the set in the end. About £300 from memory)
Study the WD can and see if you can find the word oil on it, anywhere.Ive used WD 40 on countless padlocks and door locks and they have always worked slickly?
Use 6 - moving parts?
Top Ten Most Popular Uses of WD-40® Multi-Use Product | WD-40
Discover the top 10 most popular uses for the WD-40 Multi-Use Product.www.wd40.com
See instructions - locksStudy the WD can and see if you can find the word oil on it, anywhere.
It's primarily purpose is moisture dispersant.
Mike.
You would be better off using silicone spray as it won’t clog the lock.Ive used WD 40 on countless padlocks and door locks and they have always worked slickly?
