Terry
I think I read that Amazon leccy vans have a range of a little over 100 miles ?
Not such an issue if Hydrogen was used.Battery weight is the problem on a sub 3.5 ton van, bigger batteries more weight less cargo.
And no shortage either.Not such an issue if Hydrogen was used.
No fuel eitherAn engine weights must knock a good bit off ,also gearbox ?
But local work only, very limited range, as has always been the issue, just look at the old electric milk floatsNo idea what I'm talking about SD but we are beginning to see large numbers of Amazon delivery vans and others which are totally electric. Would this suggest that some vans are already available for conversion to motorhomes.![]()
Battery size | 67kWh | 89kWh | 111kWh | 139kWh |
Driving range | 112 miles | 149 miles | 180 miles | 211 miles |
Gross vehicle weight | 4,250kg | |||
Kerb weight | 2,275kg | 2,395kg | 2,515kg | 2,635kg |
Max payload | 1,975kg | 1,855kg | 1,735kg | 1,615kg |
Add to this 1250kg of A Class coachwork, 90kg of fuel and you’ll have virtually no payload at all. Plus range will be massively less than shown here.These are the spec of the Arrival electric van. https://www.parkers.co.uk/vans-pickups/news/2021/arrival-electric-van/
Electric vans can be driven on a standard car licence up to 4.25 tons, which is why using an ali chassis and composite panels on the short range it has a payload of nearly 2 tons.
The interesting bit from the specs is the weight of the battery, to go from 67kwh to 139kwh increases the kerb weight by 360kg so roughly speaking the 67kwh battery weighs 350kg for roughly a 100 mile range. To increase the range to what a petrol van could do (500miles) would mean the batteries would weigh somewhere around 1750kg.
Battery size 67kWh 89kWh 111kWh 139kWh Driving range 112 miles 149 miles 180 miles 211 miles Gross vehicle weight 4,250kg Kerb weight 2,275kg 2,395kg 2,515kg 2,635kg Max payload 1,975kg 1,855kg 1,735kg 1,615kg
The problem being discussed is valid. However I am worried about using a MH after electric takes over. My favourite haunt is Greece. In simple terms I manage to get to the south of the Peloponnese in 5 days. With an electric range of 250 miles (say) it would take me 10 stops at least. If lucky I might be able to stop overnight at a charging point. If not it could easily cause me to stop an extra day or two.
By which time the average motorhome owner should really start on the way back home. End of Greek holiday.
The future is electric and the future is bleak.
No, the amount of solar you could fit on a van roof would not be enough to make even a minor dent in an EV's requirements.Would it be possible to use solar to help charge ? No idea on voltage on leccy vehicles but assume they are not 12v![]()
Hi, Look at the bigger picture, for example, farm tractors run on diesel, they will not be going electric. They would need tons of battery's to plough a field, HGV's, everything you buy is moved by HGV's. Isn't our brand-new Royal Navy's ships all powered by fuel oil.It looks like the nearer we get to 2030 we have decisions to make. Would you be mad to buy a new diesel van after say 2025? or do you think the prices of diesel will hold up in the move to electric, drop like a stone or maybe even go up?
I know that many of us will be able to hide our own easter eggs by 2030, but younger Funsters who expect to be motorhoming long into the 30's whats your plan? keep your van, buy newish now and keep it, wait and see, keep calm and carry on.
Not to mention Airbus and Boeing not having a useable alternative to fossil fuels, nor F1 with all its jet setting!Hi, Look at the bigger picture, for example, farm tractors run on diesel, they will not be going electric. They would need tons of battery's to plough a field, HGV's, everything you buy is moved by HGV's. Isn't our brand-new Royal Navy's ships all powered by fuel oil.
Hydrogen for long distance airlines, batteries for short and medium range.Not to mention Airbus and Boeing not having a useable alternative to fossil fuels, nor F1 with all its jet setting!
Hi Karl,No, the amount of solar you could fit on a van roof would not be enough to make even a minor dent in an EV's requirements.
In fact. In an EV motorhome it is likely you will get rid of the solar panels and leisure battery and just use the vehicle battery for the habitation stuff.
A 100AH lead acid battery equates to 1200Wh or 1.2KWh of storage. With under half of that being usable.
With a 50KWh battery in the van, you would use less than 1% of the battery to get the same amount of battery usage.
For me I can foresee me stopping at the nearest supercharger to a campsite, blatting it back up to 100% then foregoing sites with hookups or not paying the extra if it is an option.
Going off hookup will be much easier in an EV van.
Hi Karl,
As I understand they use 300 to 450 KW motors and batts can be charged using 110 / 220 / or 440 v super chargers. SPs kick out a lot more than 12v it's the charge controller that limits it to 12 v ish . Not sure on how much SP do kick out,just wondered if tech was able to do anything to help charge ?
Edit agree that vehicle battery could/ would be used but battery tech would need to improve a lot.
What's this new battery tech by Toyota ?
Hardly progress really.The changeover to EVs will not be painless. A lot of what we do now may not be possible. Restrictions on the use of ICE will increase. In the example given by Krumpli would it really affect many people if the distance one can drive is limited to 250 miles in a day? On a scale of concerns that should be pretty low down.
Who says this distance is limited to 250 miles in a day?if the distance one can drive is limited to 250 miles in a day
Again, hardly progress. I can do 500 miles on a tank and then refill for another 500 miles in about five minutes.Who says this distance is limited to 250 miles in a day?
250 miles. charge for 40 minutes then another 250 miles. 500 miles in one day should be enough for most people surely?
Technology changes.Hi, Look at the bigger picture, for example, farm tractors run on diesel, they will not be going electric. They would need tons of battery's to plough a field, HGV's, everything you buy is moved by HGV's. Isn't our brand-new Royal Navy's ships all powered by fuel oil.
Depends on how you define progress. No pollution and quieter, smooth, more reliable drive.Again, hardly progress. I can do 500 miles on a tank and then refill for another 500 miles in about five minutes.
