2.2 dpfissyes. (1 Viewer)
Jamesh
2,200
3,839
Van conversion
Caravaning since 2010
My new van a ford transit 2.2 mk8 has a dpf issue. The dash is saying exhaust filter full.
I cannot get it to regen despite driving 250 miles yesterday. Much if it in limp mode....
Any ideas? Garage suggesting clean / delete / new dpf....
Booked in Wednesday.
Cheers James
TheBig1
17,644
43,457
There are known issues with the sensors on the transit dpf. A forced regen from the ecu can be done using Forscan via the OBD port
Dec 6, 2011
11,625
25,541
South Wales
Coach built Adria
As said above, check dpf sensors first. If they are good and the dpf is blocked then a forced regen via the ecu.
I am told that forced regents can only be done twice before the dpf is shot. But I cannot confirm that.
Occasionally a dpf can be so badly blocked that it needs replacing.
Not cheap....
Zoobec
670
2,458
Peugeot Boxer PVC
Newbie
we had a Dpf type warning light come on (on a Peugeot boxer) and it turned out it was to indicate low adblue, could that be the case with yours?
J
Jamesh
2,200
3,839
Van conversion
It did say low ad blue so I topped it up.
Then it continued to say low ad blue despite adding 5l of ad blue.
It wouldn't regen despite running at 3000rpm for best part of an hour.
Im hoping the garage can force a regen on it!
Otherwise it will be a new dpf. I've found one which hopefully fits for £360 from EEC which isn't bad??
Cheers James
Zoobec
670
2,458
Peugeot Boxer PVC
Newbie
Our dpf light didn’t go off until we next restarted the ignition. Fingers crossed you can get it sorted!
Dec 6, 2011
11,625
25,541
South Wales
Coach built Adria
Now that you have topped up the ad blue, try disconnecting the cab battery earth for several minutes then replace it.
The ecu may then search for its parameters and all be OK.
Worth a try
Dec 2, 2019
4,120
9,249
South Lincolnshire
Rapido 7065+
Broken most bits now
The atomiser for the dpf regen injection device is probably blocked. It is in the exhaust before the dpf buy needs a code reader to prime the small injector pump if cleaned or replaced - a garage job I suspect.
J
Jamesh
2,200
3,839
Van conversion
Update....
Garage have said they couldn't force a regeneration so I can
1) Have it removed and decoked.
2) have it removed and deleted -illegal!
3) have a new one fitted at £700+ fitting.
Cheers James
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
I would go with Phils idea. It almost like a reset,,you’ve got nothing to lose,, (y)
Dec 6, 2011
11,625
25,541
South Wales
Coach built Adria
How will they decoke it, the inside is like a carbon fine honeycomb, I can only guess by chemicals which I suggest is likely to reduce the life of the dpf as it will eat some of it away.
The thing u would want to know is what caused the blocking to become so extreme so that the normal process could not burn it off, what else is not doing what it should..
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
other than that have you thought about a carbon deep clean? There are a few companies that do it and they are mobile.
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
By chance, I’m having my Range done tomorrow, I’ll let you know how it goes if you like,my neighbour has has his camper and two cars done and said the difference is amazing,,,let me know (y)
Dec 6, 2011
11,625
25,541
South Wales
Coach built Adria
Just to make the point..... If you know what caused this then that's fine and can be avoided or sorted.
But,
If you don't then there is a strong chance of it happening again and your hard earned money will be down the drain.
Aug 18, 2014
23,851
134,418
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Update....
Cheers James
tell them no;2 but to remove the internals & refit. or no;1 & remove interals & refit
J
Jamesh
2,200
3,839
Van conversion
Thanks guys.
Let me know how the range rover gets on.
Will get them to check the atomiser.....
I think it's done alot of low speed driving and it's limited to 60mph.... Needs a derestriction + remap!
Cheers James
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
Thanks guys.
Cheers James
Definately a re map,,, (y) (y) (y) (y) (y)
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
Little update as promised,,,had the car carbon cleaned today and a little re map done.All very tidy work,,just taken her out for a drive and the difference is VERY noticeable,,so I would recommend it,,,good luck James with your issues,hope it gets resolved,(y)(y)
J
Jamesh
2,200
3,839
Van conversion
Or No.4 - go to a garage than can check the atomizer
Correct answer the atomiser has blown new one from ford hope it works.
That's a good result. I might get it done at some point. How much did it cost?
Cheers James
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
£ 380,,,it may sound pricey, but it cleans all the sooty build up from the engine, that price included the re map, I’m going to get the MH done soon,,glad to see you have sorted your issue out (y)
J
Jamesh
2,200
3,839
Van conversion
Van back from garage running fine!
Do you think a in the tank dpf cleaner would help?
Thanks for all the help.
Cheers James
Dec 2, 2019
4,120
9,249
South Lincolnshire
Rapido 7065+
Cheers James
The atomizer really needs to be removed and cleaned or replaced. It sits in the exhaust upstream of the dpf and gets blocked with crud from the engine. It's purpose is to inject diesel and ignite it to get the dpf to regenerate. If it isn't working the dpf will never regenerate and clog up pretty quickly.
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
Cant do any harm,
drb567
Bailey
The injected diesel doesn't ignite, the increase in exhaust gas temperature is generated by a catalytic reaction within the oxidation catalyst.
Dec 2, 2019
4,120
9,249
South Lincolnshire
Rapido 7065+
Not sure about the transit but the Citroen version ignites it with a glorified glow plug and fuel injector
Aug 18, 2014
23,851
134,418
Lorca,Murcia,Spain
Transit PVC
If it is restricted to 60 mph that wants removing asap.Otherwise til then drive using 3rd as top gear.
J
Jamesh
2,200
3,839
Van conversion
I agreed getting it done asap!
Is it worth remapping?
Also the is apparently a software update to inform you its regening so might ask about that too.
Cheers James
J
Jamesh
2,200
3,839
Van conversion
A now atomiser was fitted.
Cheers James
