12v shutdown on niesmann bischoff flair HELP (1 Viewer)
Apr 20, 2009
226
134
norfolk
I have a limited knowledge of electrics but will try to explain . Went to van to get it ready to get away ,liesure batteries were flat so i purchased new set but the control panel says batteries are still flat and emergency SOS lighting is on but no other electrics are working on 12v.When i push main button on control panel i get all differant messages and panel dosnt seem to be recieving any signal to tell it batteries are ok Is there anybody who may no what i could try next or no a repaire specialist around the norfolk area thankyou
Jun 10, 2010
8,562
20,289
Shrewsbury (sometimes)
N&B Clou Liner MAN
How old is it?
@funflair may be able to help
sillybug
Apr 20, 2009
226
134
norfolk
yes it was disconnected and still the same just keeps saying batteries ect but they are new and fully charged. i read a previous post from abecist i think and have tried all the advice which he was given,nothing worked.Cant even find anybody around this area to just take a look at it .
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I don't really know where to start------- but it sounds like, the power is not getting to the main control box (electroblok??) Maybe a fuse/ breaker on main 12 v from battery------- maybe a fuse on electroblok????
What year is the van???
19,435
30,590
You say the SOS lighting is on, do you mean that you have put the SOS fuse in? if you have I would say remove it now that your batteries are OK.
How old is it?
Basically the same as ours Jon, actually the van we went to Southdowns to look at but then somebody put a deposit on it before us so we went up to Scotlandshire for ours.
And I wish I could help but it appears that these panels don't like sitting with flat batteries, as @sillybug says Robert abacus seems to have had the same problem.
sillybug
Apr 20, 2009
226
134
norfolk
HI Martin we took fuse olut but it continues to work .beginning to look like an expensive trip to travelworld
teresa
19,435
30,590
teresa
So you don't have a fuse in position 2 or 3 in the fuse box, might be worth switching all off and then disconnect and reconnect batteries, I believe that disconnecting the control panel and reconnecting can help in some circumstances, the panel that the control panel is fixed into is on spring clips sp just pulls off from the bottom edge.
sillybug
Apr 20, 2009
226
134
norfolk
This morning i have been in touch with simpsons becks and a few more nobody will touch it .Getting really fed up now cant get away cant fix it . Can i ask why you wouldnt take it to travelworld please
teresa
19,435
30,590
teresa
You could sound them out and see what they know but the factory might be a better bet(y)
Zepp
1,673
3,260
Roaming
7 Years
Hope you get it sorted you could also give Reliance a ring they might be able to help
sillybug
Apr 20, 2009
226
134
norfolk
Thanks martin but we have disconnected allsorts and reconnected done all the things we have read
. I have already rang travelworld but didnt really tell me much just how much they charge per hour
may consider ringing factory as a last resort
Teresa
canopus
6,143
10,281
rural Lincolnshire
Carado CV640 Pro
They sell motorhomes, but from what I understand and have heard, they seem to know very little about them. My opinion only.
Feb 24, 2013
13,109
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
Our Hymer does silly things sometimes, I have solved a few issues by switching off the main electro bloc or equivalent as ours is another make, switch off count to 10 and turn on again
Similarly there is a big fuse near mine 50A I think in a separate holder, try removing that and refitting
Easy stuff to try about my technical limit :)(y)
Good luck, hope it turns out to be something simple
Feb 24, 2013
13,109
101,579
Hymer S800
not long enough
Have you tried starting the engine to see what that does to the controller options? It might just reset things somehow (y)
Still thinking simple first :)
19,435
30,590
I know everybody is trying to help(y) but just to help @sillybug you don’t have elektrobloc so don’t go looking for one, your controller as you know is CBE.
Feb 21, 2016
4,924
29,767
Uk
Since 2017
Sorry if I’ve missed it........ but why don’t you take it to the garage that does your annual servicing and hab check?
Feb 24, 2013
13,109
101,579
Hymer S800
not long enough
Does it still have an off switch though? Mine is something different, but by switching off and on I have resolved daft electrical things
19,435
30,590
With reference to TW they should know there way around the CBE system as N+B vans have had it on for years, I don’t know that that many other vans use CBE so a lot of dealers and service engineers could well be stuck trying to diagnose it, Marcel leisure are agents for CBE so may be able to suggest an engineer, just a long shot @sillybug
Might be worth taking the cover off the distribution box, should be in your left side locker under the seat and then just give the relays a gentle tap with the head of a screwdriver or similar just to unstick anything that is/might be stuck.
19,435
30,590
Off and standby switch on the control panel David but not a hard switch like Electrobloc.
sillybug
Apr 20, 2009
226
134
norfolk
Thankyou zepp rang reliant this afternoon they are in touch with factory who say they think the control panel is in a tizzy abit like me at the moment and it needs resetting but didn’t say how so we wait till tomorrow when they should send the reset procedure then if it doesn’t work there is probably something more expensive wrong
UnfortunatelyReliant can’t get us in till end of may.
Just opening bottle of red think I’m gonna need it .Will update tomorrow thankyou for all your help
Teresa
Jun 10, 2010
8,562
20,289
N&B Clou Liner MAN
My cbe charger has a fuse in it.
but I also think I've seen a method for rebooting the cbe panel, that's why I was prompting @funflair. Do you recall it Martin?
