Wissel
Thanks Pausim - sounds like you have a well thought out SystemI believe my BMS steps in but this may vary from manufacturer to manufacturer. I have added an accessible fuse to the D+ signal wire which I can easily pull if I ever thought the battery was too cold, just to make sure. I have also put a remote thermometer in the battery compartment but since this is heated, battery temperature is never a problem when the motorhome is in use. When left unoccupied the battery can get cold but it still retains a full useable charge so I would just avoid charging it until everything has warmed up.
But it's how the one in this post works as a "drop in replacement" I'm curious about. Hopefully BatteryMegaUK will be in later to clarify
