- May 3, 2022
- 67
- 49
- Adria Compact DL
Perfect thanksYes it’s in the locker on the outside where the. electrics are, on the left hand side and it’s coloured Red
Very easy access as well
Ah. No worries.Sorry, thought/assumed you were comparing with the Super B batteries that the preceding half dozen posts were referring to.
Ian
Ah. No worries.Not encountered Super B. Will investigate now.
If I was you I would fit the underseat roamer 230ah and save some space and DoshSo as carthago fit the 90ah super B (I think) if you fit that at the factory is it a better option than fitting a 100ah roamer/eco power/ks retrospectively by oneself (not me obviously, I struggle with a battery swap in a smoke alarm) which I assume would be a lot cheaper. I’m just trying to see the benefits of spending say £1500 on a 90ah super B when you could fit a 230ah roamer for less
Maybe I should do less thinking![]()
£1700 on a Carthago but you do get the correct mains charger.So as carthago fit the 90ah super B (I think) if you fit that at the factory is it a better option than fitting a 100ah roamer/eco power/ks retrospectively by oneself (not me obviously, I struggle with a battery swap in a smoke alarm) which I assume would be a lot cheaper. I’m just trying to see the benefits of spending say £1500 on a 90ah super B when you could fit a 230ah roamer for less
What about a decent bean to cup machine?? Asking for a friendif you like those stupid pod coffee makers you can run one off the 90ah without tripping the BMS.
The 90ah from SuperB is a different battery to the rest of the range, the 90ah is an Epsilon uses cylindrical cells and they market it as a "drop in replacement" for lead acid? it certainly has different temperature characteristics to the Nomia range in that it can be charged at -10 deg C as opposed to 0 deg C on the Nomia which uses prismatic cells.£1700 on a Carthago but you do get the correct mains charger.
They are one of the best batteries going & if you like those stupid pod coffee makers you can run one off the 90ah without tripping the BMS.
If you are spending 300k plus on a Morelo I can see the point, might as well have the best but hard to justify on a more downmarket van.
When my Carthago comes it will probably get a Fogstar or a DIY build.
I know they change the mains charger on Carthago, I don't know it they upgrade the standard B2B.The 90ah from SuperB is a different battery to the rest of the range, the 90ah is an Epsilon uses cylindrical cells and they market it as a "drop in replacement" for lead acid? it certainly has different temperature characteristics to the Nomia range in that it can be charged at -10 deg C as opposed to 0 deg C on the Nomia which uses prismatic cells.
I know with Morelo who fit the Nomia they automatically fit a B2B/ladebooster at 90amps and 120 amp mains charger as part of the Lithium package, do you automatically get the B2B and associated wiring from Carthago when you go Lithium or is this missing as they use the Epsilon.
This might have a bearing on anybody's decision re fitting a bigger battery aftermarket which may well need B2B and uprated wiring vs a factory fit if it has already been optimised.
I’ve wondered if i’d benefit from a larger B2B tbh and would there be any drawbacks such as alternator fitment.I know with Morelo who fit the Nomia they automatically fit a B2B/ladebooster at 90amps and 120 amp mains charger as part of the Lithium package
The benefit of a larger B2B is obviously faster charge times when driving, if you don't need this then there would be no benefit.I’ve wondered if i’d benefit from a larger B2B tbh and would there be any drawbacks such as alternator fitment.
Mines a 40ah. Redarc B2B so what would he your thoughts Martin
From memory, when I looked at the spec sheets the b2b wasn't mentioned, pretty sure I was told it didn't change. Turned out the Iveco models do not have a b2b at all since it is not a smart alternator. I would not have chosen the Carthago Lithium option though, the capacity they offer is still a bit low I think. We ended up buying a dealer stock van rather than waiting an unspecified time and this came with 3 80AH gels (they offer up to 4) and twin 16amp CBE chargers. We changed that to 430AH lithium and 120AH charging - we put in a b2b mainly to protect the 16mm cable that I will upgrade at some point when its not cold and wet. We did not go for a particularly expensive battery having had 2 Mastervolt Lithium MLI Ultra 6000 before and lost out when a cell crapped out just after the warranty expired. Once bitten......I know they change the mains charger on Carthago, I don't know it they upgrade the standard B2B.
The Iveco models will/would be smart alternator but I understand that it is possible to write the smart function out of the ECU so possibly that was done, I know when Iveco first started fitting smart alternators N+B had them on their Flair range but the Gel hab batteries didn't charge until N+B instructed the local Iveco dealer to programme out the smart function.From memory, when I looked at the spec sheets the b2b wasn't mentioned, pretty sure I was told it didn't change. Turned out the Iveco models do not have a b2b at all since it is not a smart alternator. I would not have chosen the Carthago Lithium option though, the capacity they offer is still a bit low I think. We ended up buying a dealer stock van rather than waiting an unspecified time and this came with 3 80AH gels (they offer up to 4) and twin 16amp CBE chargers. We changed that to 430AH lithium and 120AH charging - we put in a b2b mainly to protect the 16mm cable that I will upgrade at some point when its not cold and wet. We did not go for a particularly expensive battery having had 2 Mastervolt Lithium MLI Ultra 6000 before and lost out when a cell crapped out just after the warranty expired. Once bitten......
But wouldn’t I have to mess about with the charger, solar controller (now I have bought a bloody votronic 430 duoIf I was you I would fit the underseat roamer 230ah and save some space and Dosh![]()
It makes sense to have the "smart" control built into the ecu rather than the alternator itself. Thanks for clarifying, so now I might think about a bigger alternator.......................The Iveco models will/would be smart alternator but I understand that it is possible to write the smart function out of the ECU so possibly that was done, I know when Iveco first started fitting smart alternators N+B had them on their Flair range but the Gel hab batteries didn't charge until N+B instructed the local Iveco dealer to programme out the smart function.
You know this makes sense votronic is no where near victron it terms of flexibilityI still have a hankering for a wall of blue, but don’t want to relocate the big victron battery to a useful locker![]()
I always liked the Votronics on the Flair but when the new ones wouldn't work on the Morelo with Lithium I went Victron instead, one "blue" controller was the price of two Votronics but had the extra capacity to cope and I have to say "a lot more features"You know this makes sense votronic is no where near victron it terms of flexibility![]()
Not all lithium batteries are the same. Just like lead acid batteries there are differences in construction. The first basic difference is cell type, some use cylindrical cells others use prismatic ones.
Renogy are using pouch cells in their Smart 100Ah battery, pictured. Eco-Worthy do too although they don't encase them in a smart aluminium case like Renogy do, they just wrap them in clingfilm..
Keep your Votronic MP430 as well as that will work OKBlimey, lithium is a minefield, i think I might stick to gels![]()
