£225,000 at the NEC
Al n Val
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
So
we’re going to the NEC on thursday, we’ll be there a max of 6 hours possibly less looking to spend (maybe) £225000 less PX
on an A Class
1. max 8mtrs
2. Not white (silver)
3. 2 berth (poss 4) so 4 belts
4. Island bed (poss singles)
5. double floor but don’t want to have to climb a staircase to get in/out
6. big garage for folding elec bikes, chairs,table but no high bed inside
7. Must be auto and poss Merc but not essential so Iveco or something else
8. enough roof room for 600w min solar
This will poss be our last motorhome so good build quality with no shitty dealer backup service would be nice
Dealer max 2 hours but pre preferred less from West Yorks, is their any good dealers out there ???
Can you think of anything else and i’m not a fan of the TV in the hab door entrance either
cheers
Al
PS. Val will not entertain rouffle leather so has to be nice n smooth
what chassis is your Crapido on ?
The trouble with a lot of new Mercedes is they are FWD !. You may have to consider Iveco for RWD ?
Also, the Sprinter 319/419/519 are no longer V6 3 litre diesels. They are 4 cylinder 2 litre..
Is this meant for me?
Have you looked at RS Motorhome?
TBH no. i’m not a fan of 1uk dealer brands as your solely in they’re hands
Similar thoughts regards Frankia, i’ve heard SMC are like most dealers, once they’ve got your money it’s curtains and you’ve only them to turn to
I maybe totally wrong of course
Upvote 1
Surely FWD is far better for the build of a MH, as you then have loads of space for under floor storage and water tanks etc, unimpeded by drive shafts?
And older V6 3.0 litre diesels are no way going to make euro 6? So given the direction of flow one would be restricting the usuage due to LEZ areas etc?
Whilst I don’t totally disagree we got our Globecar from SMC and there only a few Possle dealers in the uk. They have been fine with us.
The V6 3.0ltr has been euro 6 since 2015.
No it’s not RWD much better, I’ve lost count of the number of low profile FWD vans stuck on a bit of slippy moist grass. I’ve never seen any issue with positioning tanks on RWD vans, a lot of them have double floors for that so fully winterised.
If you lower your sights just a weeny bit, a Laika Kreos H5109 might suit you. £165k, gives you room to fit a few extras - air suspension, self levelling etc. Four seat belts, large garage, single beds, just under 8m.
We had a Laika A Class for nearly 6 years, and it was the best moho we have ever had. The Italians do have style too!
All that depends on your usage I guess.
Our 3 Mercedes Rear Wheel Drives never got Stuck in Snow. Because most of the weight is was the rear axle.
First 416CDi Chassis was superb. 518CDi was good for traction, but it was a lower chassis so you had to be careful With snow depth. They were both 4 wheels on one rear axle. The third, a 318CDi had just two rear wheels but was quite a high chassis so no issues there.
We do have a Front Wheel drive Fiat that is okay in Mud and Snow. But it's an old version with Water and Fuel tanks up front. Along with Gas bottles and batteries. So we have been okay with that.
Mercedes for years marketed their Transporter range as being superior for hill climbing and towing. Now, suddenly, thats not the case.
The
M642 V6 Engine​
Is still in production. It is no longer fitted to European Transporters (Vito/Sprinter)
Upvote 1
Right then
just got back from the show and….
we’ll be keeping our Rapido, certainly for the time being, we looked at Carthago, Frankia, Hymer, Burstner, Dethleffs and Le Voyager.
Everything we looked at would give us less than we already have, we looked at up to £265k and there was nothing we’d change to.
So getting ours sorted and fitted with VB air and that’ll be it.
Can anyone please explain why on certain A class motorhomes based on Mercedes that the front wheels are narrower by approx 1ft than the rear wheels?
The front wheels were set into the front wheel arch so much it just looked wrong to us.
Definitely not. All the weight is in the rear..its easier to push weight than pull it and front wheel drive loses traction far easier.
The best built vans are rwd
£9 for a glass of wine! We normally get 2 for just over a fiver in most spoons.
The Sprinter chassis does not always suit a wider A Class motorhome and you do get the recessed front wheels. We found this on a Mercedes Hymer we had.
Conversely, the Ducato cab is often mated with an Alko chassis which is made for motorhomes, and additionally gives you a wider rear axle for stability.
Have an Adria now but wouldn’t buy new now. People have so many issues
TBH we love the new SuperSonic, especially the front end, but as you say i’ve read about too many issues with them.
Our 2 friends both have them and both say build quality is not as good as we’ve got, that and the interior furniture and flooring was too dark and no option to change. 😟
The only time I got stuck on a bit of slippery grass was in my rear wheel drive Mercedes Hymer. The traction button on my Fiats has always got me moving. With FWD you do have to be sensible about keeping the steering straight. As for the other benefits of RWD I really don’t think I am looking for them in a motorhome but the FWD on my Carthago meant I had lots of underfloor storage and could get better weight distribution.
Right then
Exactly my view. Rapido do a lot right. And you can almost get two for the same money as a Carthago…..
Including FWD…..
Not sure about best built? That suggests quality.
Design wise, guess it depends where you go and how you drive.
Ive never had a problem with a FWD van, know its limitations and keep off bogey ground…
Seen and towed many a RWD lorry off fields at horse shows!
Yes and that's why the best brand motorhomes are rwd.
No need to go on boggy ground just try driving up a steep windy mountain pass.
I've had various vans of different lengths weights etc . Every fwd I've owned lost traction on those roads.
You will never and I repeat never get a rwd drive motorhome spinning wheels on tarmac .
Weight over drive wheels has been best since horses and carts and always will be
You seem obsessed with grass and fields. Its motorhomes I'm talking about not cows , they drive on roads.
I've personally seen fwd, rwd and 4wd get stuck on grass sand etc etc.
That's driver error. Stick to roads and rwd will always put perform fwd for traction.
As for all the stuff about storage again you'll find the best brand motorhomes are rwd and have the largest amount of storage and payload .
Could not agree more, as per my posts above. #34 and #72
And 26 ton horseboxes, still towed many off with my JD…
But its a bit like the 4x4 Chelsea tractor situation….90% of people are fine with FWD MHs… which seldom leave tarmac - and load them sensibly…
Right then
Our Frankia has front axle and rear axle widening to counter act this look more costly though all done along with the air by Meier before Frankia build.
Is your jd fwd or rwd ?
How many fwd tractors do you see?
Only because they are built higher to accommodate rear wheel drive, I have much more storage on my FWD Carthago than I had on the similar size RWD Frankia.
That’s why I said various and not all Dave, the Frankia’s looked well tbh but the first thing we noticed were how shallow depth the steps were getting in/out.
Why oh why have they done that, it’s bloody stupid and everyone we saw going in and out remarked on it.
