My Minimax has a safe working load of 200kg (if you see me, you'll know the reason why!)Most are 75kg max I just scrape in.
Well im around half that again lol ... didn't seem to do any damage
I use a very similar 3-way ladder, configured as a tall stepladder, to wash the roof of the van. Using a long handled soft brush, bucket and hose. I find it stable enough to work from although I never climb onto the roof itself.I used these ladders from Screwfix, less than £100, Adjusted the stops so that I can raise one extra rung and tie the side of the ladder to the wind out mechanism of the awning
Mac Allister 4m Combination Ladder - Screwfix
Order online at Screwfix.com. Versatile aluminium combination ladder. Can be used as a 2-piece "A"-shaped (step) ladder, or converted to use as an extension ladder. Features high resistance steel hinges, enabling simple and safe extension and safety locking straps to avoid accidental opening of...www.screwfix.com
Edit: it also fits in the garage
That is not the roof of the van.My Minimax has a safe working load of 200kg (if you see me, you'll know the reason why!)
Base pack starts at £500.
I used mine like this with the extending bit one rung higher (tied to the wind out awning mechanism) and use that part as a hand grab when getting on or off the roofI use a very similar 3-way ladder, configured as a tall stepladder, to wash the roof of the van. Using a long handled soft brush, bucket and hose. I find it stable enough to work from although I never climb onto the roof itself.
Big stepladder and just walk on it. Job done.Has anyone got a permanent solution to getting up high to the motorhome roof for washing etc?
I've used the forklift at work recently but still a bit of a faff. I'll be wanting up soon to give it a wash and polish, remove the sat dish and eventually add a solar panel or 2. Been looking for small platform scaffolding but nothing coming up for a decent price.
Found this on ebay but not entirely sure it's as robust as they say it is...
Aluminium Scaffolding Ladder Work Platform Multi Combination Multi-purpose Step | eBay
3-in-1 ladder: leaning ladder, step ladder and work scaffolding. Combination Ladder Aluminium Foldable Platform Scaffold Multi-Purpose 3.5M UP. It can be easily converted into a ladder, double ladder or working scaffold.www.ebay.co.uk
Storage is not really an issue as will be stored at work.
Anyone got anything for stable access to the roof?
I fitted two solar panels and a satellite dish using an extending surveyors ladder with foam wrapped around the top. Once you get everything you need on the roof it’s very straightforward to do the work and very safe.I've done the whole ladder thing before but it's a pain in the arse trying to move around, up and down everything you need.
Like I say going to be taking the dish off and adding some panels so was looking for something a bit sturdy. Might take a punt on that ebay item as it's the closet I'll get to a small scaffolding section with out paying big bucks.
Very early 90s I saw a few houses with bamboo scaffold in East Germany.What's wrong with Bamboo, the Chinese have been using it for 100's of years?
Cheap, strong and it won't go rusty!
Many up to chimney pot height
Still see it in India & Thailand, even on multistory blocks all tied together with string & the workers in work boots, we call them flip flops here.Very early 90s I saw a few houses with bamboo scaffold in East Germany.
I got one of those platforms and ended up giving it away as it was very rockyHas anyone got a permanent solution to getting up high to the motorhome roof for washing etc?
I have a Younger Mini-Max scaffold tower that I used to use for repairs on my double deckers.I got one of those platforms and ended up giving it away as it was very rocky
Me too.am feeling smug, because we have a fixed ladder on the rear of the MH and can walk on our roof.
If using water I wear proper deck shoes
Yes looked at them and very pricey..I might try that system what attaches to ladders and has suction cups and a strap to stop you falling off. About 90 quid I thinkI have a Younger Mini-Max scaffold tower that I used to use for repairs on my double deckers.
Not cheap but solid as a rock with adjustable legs etc.
A 3m step ladder works fine for meI use ladders around with some polystyrene pads, it is a pain but does the job. I personally wouldn't get on roof, A) management says not, B) knowing my luck I would damage roof.
Ditto.I got one of those platforms and ended up giving it away as it was very rocky
