What Should My Tyre Pressure Be, Please? (1 Viewer)
19,613
31,484
Really you need to know the axle loadings from a weighing and the tyre load rating, then you can make a decent estimate in my opinion.
Feb 14, 2021
3,812
8,194
Milton Keynes, UK
Burstner Lyseo 727G
It should be somewhere on your vehicle - often on the inside of a door panel when you open the door. Or in the manual.
Typically they can be 79 psi.
Feb 21, 2016
4,931
30,296
Uk
Since 2017
Some tyre manufacturers have websites that will tell you,try googling them.
The Tyresafe one,already mentioned,is good.
Most tyres have their maximum pressure limit on them. Also check their age,which is usually stamped on the inner wall,being four numbers,the first two is week of production,and the last two are the year of production. Check for cracks and bulges.
Lots of other very good tyre threads on here.
zac
2,635
1,899
Basingstoke
Rapido A CLass 10000
since 2013
This will help if you know the axle loads.
Just used that site to check mine and for some reason its way off, with the correct axle weights on each of the 3 axles on my tag it comes out at 44 psi on the rear. If i put that in it would be dragging the floor
2,583
11,471
Sold
As said, the correct size tyres and pressures are on the data plate on the drivers door pillar or user manual.. but only correct if you have a PVC or coach-built on a van chassis that has not been up plated.
On a tag axle or coach built with an Al-Ko chassis they will be different from the original base vehicle data ..
This is the sticker from my Ducato 2.8JTD .. LWB panel van . MAM 3,300 kg
4.i and 4.5 bar ... 59 and 65 psi
HKF
HKF
2,144
4,417
The Charente, France
Benimar Europe 740
Since August 2021
Thank you so much for all the replies so far. One thing that's confusing me is that some say to look at the sticker on the door pillar and some say to go by the figures on the tyres themselves. And then, some say that the figure on the tyre is the maximum and that inflating to that pressure risks a blowout. The door pillar one has always confused me because surely it depends on what tyres you have? Anyway, I'll try to get to the weighbridge again soon and see what my axle weights are. Then I'll come back and let you all know, together with a pic of the sticker on the door pillar, so that I know what they should be :)
54,328
153,808
That is a max inflation figure but it only applies to the American market, so you can ignore it.
19,613
31,484
The correct pressure is directly related to the axle load and the tyre load rating, so you should have tyres fitted with the correct load rating or higher, it's not different makes that really make a difference it's the load rating figure, ie 112,116,121 etc, that is why it always comes back to knowing your axle weights ;)
zac
2,635
1,899
Basingstoke
since 2013
Forgot to include this but which seems crucial, so they say if CP tyres fitted which is what I selected anyway then to inflate the rear to 80psi which would be a very hard ride.
Mine are normally 70psi all round but it looks as though i could reduce that on the front by a smidge.
Apr 22, 2018
6,871
12,672
Herts.
Adria Coral lowline
I know this is what is said, but can you explain why, or what that means?
Why do Americans need to know this, and no one else does?
54,328
153,808
No a clue, may be something to do with high temperatures in some states like Nevada.
Jan 2, 2017
682
1,998
Buckinghamshire
Globecar
Interesting, thanks. The readings surprised me a little. With my axle loads of 1850 and 2000 it gave me 53 and 80 psi. Then I put in 1850 on each axle and it still gave 53 and 80.
54,328
153,808
If you put in CP tyres it always gives 80 on the rear, if you put your rear axle weight in front axle box you get a sensible pressure.
May 26, 2023
431
1,218
East Midlands
Swift c404
On my tyres there is no mention that the maximum permitted tyre pressure (69) only applies to the American market, is this a fact or urban myth, interested as door pillar says 79psi all round, although I do run at 60/65
Dec 2, 2019
4,205
9,433
South Lincolnshire
Rapido 7065+
Broken most bits now
My Michelin CP tyres say 69psi somewhere on the sidewall but the manufacturers have said squeeze in 80psi all round. I run somewhere in-between for comfort and 4 years and 30k later I'm still here to tell the tale 😂
AlunandFelicie
667
8,005
Burstner lyseo time
Those are the max what are the axle weights you run at?
That is what you set the tyre pressures for.
Need to get to a Weighbridge then?🙂but presumably less than the max so 55f 70r should be good? I currently run at 80!!!! All round ,bash ,bang ,clatter oh my spine🤪
Aug 29, 2018
59
45
County Durham, UK
Hymer Free 600
Only a year
Okay, so looked at labels and tyres and checked to get differing results.
Tyres are 225/75 16R 116
Label inside door says 5.5 bar
Other door has axle weights of
Axle 1 2000 and axle 2 1850.
If I go 1 = front then pressure in front tyres is 3.7 bar
If 1 = rear then pressure in fronts changes to 4.2bar.
Rears in both cases are 5.5.
The tyres were inflated to 3.7 bar all round by dealer at delivery.
It is a Fiat Ducato 6m PVC from Hymer.
So what is correct?
Feb 14, 2021
3,812
8,194
Milton Keynes, UK
Burstner Lyseo 727G
So what is correct?
Has one of the stickers got the Hymer label on and the other perhaps the original (pre conversion) Fiat one? 5.5 all round is fairly typical for motorhomes but PVC maybe different.
Aug 29, 2018
59
45
County Durham, UK
Hymer Free 600
Only a year
Think both are the Fiat stickers.
We are away in van at the moment.
Thought I had Hymer info with me but don’t so will check again when home at weekend.
CAB96
857
1,734
Stockport, UK
T6 Leisuredrive
So what is correct?
Axle 1 is Front.
54,328
153,808
That's ilrelavant those are max axle weights you set the tyre pressures for the actual weights you run at. So you have to go to a weighbridge fully loaded to measure the axle weights.
