Waste system pipes (1 Viewer)
Dec 30, 2015
1,428
1,276
Bury
Pilote G650L
Three years
Has anyone had to change the pipework and valves underneath? Previous owner changed drains to UK nearside. Poorly. Weird materials and leaks. Any suggestions for best source of pipes and ball valves? The sheer variety of non matching systems and sizes is driving me mad. It's a G650L.
Lenny HB
53,473
150,175
On the coast in West Sussex
Hymer B678 DL
Have a look at CAK Tanks they keep most of the bits continental Motorhomes use.
Llink to online shop
Dec 12, 2010
5,414
21,592
Cumbria
since 2011
After a tyre blow out ripped off my waste tank drain and valve, I got replacement parts from a local koi carp stockist. Normal plumbing supply shops didn't keep any of the sizes I needed.
May 14, 2014
617
744
Now a little one
Pilote like most French manufacturers use 40mm OD pipework which is not the same as UK standard waste pipe.
Link to eBay vendor who has all the pipe and fittings you should need.
TheBig1
17,635
43,358
I installed an electric dump valve to our van and had reducers 3d printed to fit the random size pipe used by rapido
acropolis22
Dec 30, 2015
1,428
1,276
Bury
Pilote G650L
Three years
Yes, you are right. I'm finding this out the hard way.
Feb 18, 2022
30
57
East Kilbride, Glasgow, UK
Pilote 696U
Used to drive a bongo and tow caravans
My pilote has a manual drain which you pull to open unfortunately it’s in the centre of the van. It is a weird size any ideas of an adaptor to push in hole which will allow me to use a fully serviced pitch.
TheBig1
17,635
43,358
have one 3d printed to suit your choice of pipe. PaulandChrissy can usually offer this service
Mar 14, 2019
1,124
1,123
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
A number of Continental use 40 mm which gives better draining and filling. My water inlet is 40 mm as is the drain from waste and fresh. You have to keep to the side of the drain pipe when opening the valve otherwise you get very wet feet.
Mar 14, 2019
1,124
1,123
Elddis Autoquest155
Since 2018
Does it have a bayonet fitting on the exposed end. Mine does which means a length of 40mm flexible pipe comes in handy when draining into the dump in that you do not have to be over it on the site just within range of the flexible
Nov 8, 2020
638
1,267
Harpenden
Auto Trail Comanche
If you need something special made, let me know. We are off to Spain at the end of the month, so if you do need something don’t leave it toooo late in the month.
PaulandChrissy 👍
