VFD-Variable frequency drives for my beautiful drill- advice please (1 Viewer)
Aug 10, 2012
844
914
cambridge
Globecar
since2001
I have a fantastic old Elliot pillar drill
but its 3 phase
I had been using it on a converter that I rescued [brand new] from a skip [I think it may have been a VFD but not sure]
After years of great service the converter started to trip the main earth leakage so I returned to that place, a skip
So... I need to run my 3 phase drill on my 240 single phase supply
Straight forward 3 phase converters are more than the drill is worth
Would this unit below do it?
Link Removed
I have searched and found people just using capacitors but that seems a bit heath robinson
Any advice from the collective appreciated
Nov 2, 2014
332
295
Maldon Essex
should be fine as long as your motor is duel voltage 410v and 220v three phase if it is you will need to change some links in the motor if it's been run on 415v three phase.
Post a picture of the motor plate and the connections in the terminal box of the motor.
Chris
Jaws
23,842
72,776
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
A bit of lateral thinking.. Why not replace the motor ?
That is what I did on my lathe.. Plenty around ( lots on eBay and cheaper than the converter ! )
Dec 12, 2010
5,436
21,713
Cumbria
since 2011
I put a single phase motor on my Elliot years ago, it also has a foot mounted switch which is a real boon.
When you look at modern offerings of Chinese machine tools you have to wonder how many of them will stand the test of time ?
I am on the look out for a converter for my recently acquired surface grinder as the motor is integral with the head casting so can't be changed.
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
The shaft is a awkward size.
I can only find a motor that fits at a cost of £180 plus switch
The cheap machine mart ones are metric
Hey ho
Jaws
23,842
72,776
Thetford Norfolk
C class, Chieftain
Hey ho
What is the HP and is it belt drive or is it cog drive ?
MikeD
3,936
3,697
London
IH PVC
Since 2012
I put a single phase motor on my pillar drill - Not as much power but works a treat. (y)
Jaws
23,842
72,776
Thetford Norfolk
C class, Chieftain
Ok.. in that case why not get a replacement motor ( as I said, several on fleabay both old and new ) and if need be get a replacement pulley wheel ?
They are cheap as chips and can even get new ones with no hole drilled at all, so you can drill the shaft hole your self and cut the key way.. no worries :)
I am away tomorrow but I do have a couple of motors sitting around.. I doubt they will be the right power to be honest but if one of them is, you can have it for postage costs..
Aug 6, 2013
11,959
16,576
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I changed the1ph motor on my pillar drill to 3ph just so I could use a VFD. No belt shifting, smooth running, soft start, braking, instant reverse, no comparison. Stick to your original idea - if you have been used to VFD going to 1ph will feel like a step backwards.
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
I hae a spare 220 single phase motor and switch from my lathe if you want I will photo and mesure the shaft.
my motor is foot mounted. 15.8mm = 5/8"shaft
1/2 hp:)
neil
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Its funny but thats where I started:)
I don't have a wiring diagram for the motor, does the wire polarity matter, motor terminals are labeled 1 to 6 with links on three of them?
Sep 23, 2007
1,713
1,975
Leicestershire
4 and many as a tugger
If your supply is on a RCD it is not uncommon for it trip when using a VFD.
Sometimes it will trip sometimes it won't.
So a new VFD may not solve the issue you mayneed to change the RCD.
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Thanks Steve
I am away for the weekend now so can I get back to you on Monday
Neil
Dec 12, 2010
5,436
21,713
Cumbria
since 2011
My motor's 550 Watts ( roughly 3/4 hp) and 2800 RPM. I run it mostly on the second smallest motor pulley and just toggle between hi and lo on the gearbox, does most things I want but like Tony says a VFD would be of benefit.
Jaws
23,842
72,776
Thetford Norfolk
C class, Chieftain
Neither of the motors I have are any good.. both rated at 1/4 horse :-( Sorry
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
so an update..
After thinking long and hard and been offered a motor [thank you!]
I have ordered one of these
Link Removed
and some 4 core cable
question , is there any particular way to connect the three phases to the motor as I have never worked on 3 phase?
N
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
that was what i went from, but I agree its not mega clear
