Minxy
- Aug 22, 2007
- 32,667
- 66,604
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
a bit like a metal giraffe with its head chopped off!
Just came across these:
https://www.thefirepod.com
Looks more versatile than an Uuni but also larger and more $$$
£700 you can buy a lot of pizza
I use Antonio Carluccio's
I just brought the gas add on. Now I just need to sell off the 3 bags of pellets I brought last year lol. Certainly won’t need both now. Anybody for some cheap original pellets.
I hope it is, it says it has twin burners which should be good enough. All my other appliances are gas so makes sense to have this one the same. I will use the quick release connectors for ease of use.Let us know how you like it vs the pellets. Certainly looks more convenient but just wonder if the results are the same ?
Also have an Ooni 3 and just brought a couple of mods off eBay that convert the 3 to burning wood instead of the pellets so will be interesting to see how that goes.So with 3yrs of using the Uuni 3 run on pellets and having cooked a few hundred pizzas on it i've decided to upgrade to gas.....
But rather than just buy the gas kit for the now called Ooni 3 i decided to buy a new model, the Koda. Similar size to the current Ooni 3 but a little more portable (no chimney or door) and it's a dedicated gas model that i'll run off the vans gas supply.
Looking forward to temperature stability over a decent cooking period (we tend to cook 6 pizzas each time, one after another) and easier lighting
Any bbq (gas or charcoal) with a pizza stone is enough to make a good pizza.
"good enough" maybe but it won't produce anything decent though
Yeah it would, and has.
This is exactly what we need Howard H ?First results off the Koda on Saturday:
View attachment 384841View attachment 384842View attachment 384843View attachment 384844View attachment 384845View attachment 384846
Average cooking times was 80-90 seconds per pizza. Tried a few heat settings and concluded that at around 80% seems to be about right and they seem to need 20-25 seconds on the first cook, then 15 seconds ish for each additional side (counting 4 sides if that makes sense). It made it so much easier cooking with gas, no temperature swing and no faff with the fuel hopper etc, just a much more controllable experience. Will make it a far more manageable and predictable process when we're out camping with it.
That looks good, I guess the internal temperature must be very high, 400C+ I suspect to cook that quick.First results off the Koda on Saturday:
Thanks for the update.
Have you tried with a pizza stone?View attachment 386432View attachment 386433
I'd love one of those ooni's but just can't justify it at the moment so I've been perfecting my technique on the gas webber over the last month or so. Mini pizza seems the best bet to make life easy getting a very thin pizza onto the grill, minimal non wet toppings very important so meat and cheese really plus a bit of chilli or rosemary, grill on lowest setting and a few chunks of applewood around the edge and a roasting tray placed over the pizza to help reflect heat back to the top of the pizza. This is the best pizza I've managed to make and used to do them on a cast iron griddle at home at 300 degrees but they would not bubble up and crisp up as well as these. 4 of these is enough for 2 people.
