- Oct 8, 2014
- 1,544
- 4,565
- Compactline 143
- I'm a newbie and always will be. You never know it all.
To me that looks like the way not to do it.
Looks like I may be passing by your house in the not to distant future then.
I would be tempted to start to upgrade it all but that would be a big job on something that works at the mo. Can you suggest a way of just upgrading the EBL 119 to something of a more modern platform? or would the video shown by Leiosurebit be a good option to upgrade all the bits?You can but not ideal, you would need to set the EBL to Gel, it will be OK if you don't use EHU very often just occasionally. The problem with the EBL it has a long absorption phase either 8 or 16 hour depending on the model, this is not good for Lithium.
If you are just going to use EHU for the odd night it will be fine otherwise fit a proper lithium charger.
Interestingly all Wildax vans with their “no gas” option now come with Clayton units, 160amp lithium ( option to add another battery), 3000w inverter etc. Getting good reviews from users, as you say the advantage is ease of install and everything in one compact box. As others have commented I’d be worried that everything needed removed if one component failed, not sure dealer would be keen on opening up the sealed box?Thanks, folks for all the advice and help. I am nearly there now. I know what I need and how to put it all together. I have had some information from Autotrail but not quite what I want. I am awaiting a further response in particular how to disconnect things and connect my system in an unintrusive way that will not invalidate the warranty. I have also looked at an integrated unit from Clayton Power. These units have everything built into one unit and can be very easily connected. One major advantage it can be easily removed and installed elsewhere. Anyone got any views on this?
Wouldn't want to take the risk, Votronic do a mains charger, B2B & solar all in one box no thanks, wouldn't want to be left without power if one item failed.Interestingly all Wildax vans with their “no gas” option now come with Clayton units, 160amp lithium ( option to add another battery), 3000w inverter etc. Getting good reviews from users, as you say the advantage is ease of install and everything in one compact box. As others have commented I’d be worried that everything needed removed if one component failed, not sure dealer would be keen on opening up the sealed box?
