TyrePal 26% Off TB99 & TC215 Funster Discount Code Until 31 December (3 Viewers)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Website says 9 grams but will not affect the wheel balance.
Of course it will affect wheel balance, the wheel will be 9g out of balance assuming it was in balance before.
However the question is "is 9g significant ?". Probably nothing on a MH with big heavy wheels.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
A quote from their web site
TC215B/TB99
The sensors for the TC215B and TB99 are 20.5mm diameter x 20.5mm long. When fitted they extend 12.5mm beyond the length of the tyre valve.
They weigh 9g which is within the tolerance for most wheel balancing, so rebalancing after they are fitted is not usually necessary
Hope this helps
premiere99
72
31
Medomsley, County Durham
I notice the sensors are 20.5mm in diameter. Will these fit on a standard Fiat 15 inch wheel with the Fiat wheel trim on.
Fitted them yesterday on x250 with 225/70 R15C 112/110R Toyo HO9 tyres, could not tighten the security screws but no problem with balancing upto 65mph on the A1 today and we have standard Fiat wheel trims.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
We have not had any problems with wheel balancing when fitting TyrePal to our car (Citroen) & locking screws are a bit fiddly but worth the effort as do give piece of mind. Not tried them on the motorhome yet (Ford Transit) but had a quick look & sure they will be fine on there too.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Mine arrived and they are sitting on the side teasing me along with the tracker. - New MH hasn't arrived yet. Only built on Wed should be here and ready for 12 Dec :clap:
One note though, they do not recommend fitting if you have Aluminium V/V stems. Dissimilar metal corrosion with the brass screw thread on the Tx.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
We have just sold our old car & although the new one has a fitted Ford TPMS system it isn't as good as the TyrePal for monitoring so will try using the two together. Has anyone tried this?
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
According to TyrePal we should be able to use it in conjunction with the Ford (as well as other car manufacturers) TPMS system (y) :
"With regards to putting TyrePal with your internal TPMS system built in the car as well, they can both work separately. Your car will tell you there is a problem, TyrePal will tell you what the problem is, (high or low pressure / temperature) and which wheel."
Just need the rain to stop now in soggy Somerset so we can get it fitted...
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Great news - can confirm that the TyrePal works well when used on a vehicle that already has manufacturer fitted TPMS (y) When we got our new car (with Ford TPMS) thought we might not want/need it or might cause some clash but missed the monitoring feedback that gives more piece of mind so happy now we have both :) Probably just as well as we don't have a spare tyre just on of those repair kits....
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Just spotted that if you have TyrePal fitted some companies offer a 5% discount on motorhome insurance - so far Camping & Caravanning Club Clubcare, Shield Total & Crusader. Not heard of the last two but have seen mentions of the C & CC insurance on the forum before - every little helps!
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Time is running out on this offer now! Understand that we have the biggest discount that TyrePal offer which is unlikely to be repeated any time soon. This offer is only valid until 31st December 2015 - please order before the 14th December for delivery in time for Christmas as TyrePal close down from Christmas Eve until the 4th Jan.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Only 3 more days to go if anyone wants a TyrePal delivered before Xmas...
mikethom
7
332
Wolverhampton
Low Profile
Since2011
Thanks for that Wombles have been thinking about one of these for a while.
The negotiated discount made my mind up.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Last chance to buy with our special Funster rate - discount code MHF1510 expires on 31st!
Allan & Loren
1,736
2,630
Leyland, Lancashire
Autotrail Dakota
Since 2014
Do you know if the tc215b system be suitable for our rv which weighs less than 7.5tonne or would we need the tc215e series?
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Final bump - last day for the discount code to work!
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Have been in contact with TyrePal to see if they can extend this 26% discount for Funsters but currently waiting to hear back...
In the meantime there is a current Caravan Club discount code CC1602 which gives 20% discount on TC215 & TB99 until 29th February - not as good as our Funster discount but better than nothing if you need to buy now :)
Nov 23, 2011
479
405
durham
Lowline
since 2006
I bought and fitted the TB99 unit in December. This week we had a few days at the CC site in Bury and on the way down after about 80 miles the console which was on top of the dash mounted reverse camera next to the RH door pillar lost the signal from 3 of the sensors. Within a further 20 miles it had partially recovered to show only 1 lost signal. For the return journey I repositioned the console to the centre of the dash on the clipboard part and it performed perfectly. I assume as I travel with the reverse camera on it was interfering with sensor signal. Its surprising how much the tyre pressures increase with temperature.
If you have missed the Tyrepal offer Snooper are offering a similar unit with 20% off for £99.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
UPDATE: Just looked on TyrePal website & see that the TB99 is on offer there at £99.99 http://Broken Link Removed with code W012016 so almost 26% off anyway at the moment :doh: but CC code still needed for TC215 unless we get a new Funster discount code.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Having had no reply from my email checked Linkedin & found that their marketing executive was made redundant in December :( Have emailed via their website to see if they have someone else who can offer us a deal. In the meantime the £99.99 for the TBP99 on their website is good & the CC discount for the TC215 does run until the end of February :) We have built in TPMS on our new car but still like having the TyrePal fitted as well for constant monitoring (y)
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Update: Now have a new contact at TyrePal who has responded to my email so will post again if they can offer us any Funster deals or discounts...
Jan 19, 2013
132
109
Worcestershire
since 2010
Hi, does anyone know of a discount code for the TC215's.... either MHF or CC ?
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Try CC1411 for £20 off TC215 which currently works (y) - won't work on TB99 as both the old & new solar versions are currently on offer already.
