which is the metering pump? is this the deisel small pump that feeds the boiler?If you have good access to the boiler ,when there is a fault there is a Red led light inside the wiring area that flashes a sequence that gives u an additional fault code that can also be checked , I had this code in October and it was my metering pump that had failed but I never had any of the E120/130/140 codes
link for blink codes-https://www.dometicrvcentre.com.au/documentmanager/item/134
“Ensure 12V power supply under load at appliance” might be a good place to start.
One big difference between the diesel and gas combi boilers is the diesel one takes a lot more from the 12V supply to get it fired up. This is because it has a glow plug that needs to get very hot before the boiler fires and the glow plug takes several amps. Once fired up the glow plug turns off.
If the 12V battery is not well charged the voltage might drop during the firing up phase and give rise to the fault codes. I don’t have any personal experience of the D version (yet) but it seems to me like it would be worth checking the voltage whilst the boiler is trying to fire up.Thank you for tis information, im having teh same error code. 122, both when on diesel or electric (plugged into the land supply). I am also getting a 164 code when on electric and plugged into the land supply.
Yeswhich is the metering pump? is this the deisel small pump that feeds the boiler?
