Tessoro 481 reversing light comes on with rear foglight (but not when reverse selected) (1 Viewer)
NewToMoHo2022
4
10
Benimar
Took our 2019 Tessoro 481 for its first MOT and it failed because the reversing light doesn't work when reverse gear is selected. However, it turns out that it does illuminate when the rear fog lamp is switched on ! Has anyone else had this problem ? Alternatively, can anyone advise on how the diagonal LED reversing light is held in place ? Just wondering whether I can simply pull it out . . . . .
Oct 6, 2021
566
910
PVC
Check the connection box for the rear lights under the back of the van, its probably full of water.
NewToMoHo2022
NewToMoHo2022
4
10
Benimar
Thanks pappajohn and Old Gibber for prompt responses - I'll get under the van again and try and pursue both those trains of thought...
NewToMoHo2022
NewToMoHo2022
4
10
Benimar
Well, just in case anyone ever has the same problem in the future - I did check the connection box for the rear lights under the back of the van, but no water and all seemed secure. The earths looked OK too, so - with the aid of a wiring diagram helpfully supplied by the Benimar technical desk - I followed the coloured wires to the back of the LED reversing lamp strip and found that the grey "Antiniebla" (fog light) wire was connected instead of the violet "Marcha atrás" (reversing light) wire. Connecting the violet wire to the lamp cured the problem !
denisejoe
5,634
12,107
Warden isle of sheppy
Since 2004
Check connection on back of light there may be another wire in there that is the reversing lamp wire had it on a caravan the only difference between uk and lhd wiring at the back are reverse and fog wiring
Northernraider
27,505
178,753
On the sofa ....
Mobilvetta eurayacht
On and off since 95
It sounds like it was set up for continental use rather than uk .
Usually its one of the things that need changed as foglight is on the wrong side
Northernraider
27,505
178,753
On the sofa ....
On and off since 95
Posted at same time but similar thoughts
Sep 29, 2009
975
672
East Anglia
Roller Team
Since 2009
Had a friend with a similar problem with hymer a class, on first mot the fog light was found to be on the wrong side.
Aug 23, 2022
Benimar Tessoro 481
Just found this site, thought I'd give a heads up on reversing/fog lights.
I had rear bumper replaced on my 481(don't get into this situation as it's over a thousand quid).
Went on a trip to Dartmouth on way home big loss of power - AA ford recovery came and engineer tested and changed an injector. He also did an engine and lights test which gave same results as original post.
Took back to distributors and they fixed problem.
I now think it was always wired that way and wires were re-replaced on repair.
Apr 27, 2008
11,851
14,093
Eastbourne East Sussex
Hymer low profile
Since 1972
Both of my last two motorhomes have had two rear foglights and two reversing lights (French and German), my car has two reversing lights and one rear foglight in the middle. Seems a bit penny pinching to only fit one of each when most people use motorhomes in the UK (even if like us it's only to drive to the tunnel) and in Europe.
