SOG Fan Broke- Dealers Mark Up is Shocking (2 Viewers)
Abacist
3,811
11,281
Devon
N & B Arto 88F Tag
since 2013
Without seeming a total dummy 🙄
Could you not get a 12v fan of the required spec and fit it into a bit of tube the correct od.
Or even cut the old fan out of the tube and fit a new fan 🤔
Sounds simple doesn’t it!
You try it!
Feb 27, 2011
14,801
76,466
UK
Self Build
I just did a quick rough back of the fag packet calc on how much I could make an alternative for that would be commercially viable for me to make by hand.
I could do a cheap one for myself. But for one that would be sellable as a product I couldn't beat the price of the original without working my nuts off for very little money.
Minxy
32,700
66,738
E Yorks
Carthago Compactline
Well you did want suggestions as to what new hobby to do in your workshop! 😄
Feb 27, 2011
14,801
76,466
UK
Self Build
That one is 32mm dia SOG fan is 20mm.
I don't think you are correct. The image shows this code
D341T-012G
Which could only be
D341T-012GK-2
The 2xmm fans from Micronel would have a code starting with D2 Not D3
Terry
11,941
9,134
Lincolnshire
Can't remember ;)
I made my own SOG years ago and was determined it was not going to cost me a penny- basically from bits I already had 😉I posted on here. Sorry no link but if anyone finds my original 👍 It would be a very early post from 2007/8
Just done a Google search for 12v Inline fan - loads from £12 to £25 👍
Jun 12, 2018
83
98
It is a lot but the roof ones are a lot different to the toilet door ones, no idea why it costs so much to be honest as its just a small fan in a plastic housing.
The toilet cassette door ones are more expensive than that.
Feb 27, 2011
14,801
76,466
UK
Self Build
I just followed your link, just had another look, boths links are for a 36mm fan.
Either I didn't explain myself very well or you misread what I meant :p
In post #11 there is a picture with a partial part number.
D341T-012G is what I can read.
This only matches the full part number
D341T-012GK-2
Which is a 34mm part.
If it was a 20/22mm fan then the part number would start with D2 not D3.
If you go to their website and use this filter https://www.micronel.com/en/productfinder/?sort=&product_line[]=Tube Fan&pressure=0&freeflow=0&size_square[]=&voltage[]=&electrical_power=&brushless_driver=&for_breathing=&o2_resistance=&acceleration=
You will see all the Micronel Tube fans.
Look at the size vs the part number and you will see that D24 is 24mm D30 is 30mm and D34 is 34mm etc etc.
Hope that clears it up?
Aug 6, 2013
11,959
16,577
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Feb 27, 2011
14,801
76,466
UK
Self Build
Here's one:
Yup, that will shift the fart/poop smells nicely :D
Notice they don't specify the static pressure or freeflow?
Also will it work ok in a humid environment with possibly corrosive/acidic gases?
Aug 6, 2013
11,959
16,577
Kendal, Cumbria
since 1999
At that price who cares? Thetfords own version fits under the cassette and uses a standard computer fan.
Feb 27, 2011
14,801
76,466
UK
Self Build
My point was that if it doesn't specify the amount of air it can push and what the static pressure is. I very much doubt those figures are going to impress. I suspect this fan would not work for the purpose.
A computer fan is much larger so can pull the air.
Aug 6, 2013
11,959
16,577
Kendal, Cumbria
since 1999
The "computer" fan Thetford use is around 40mm square and moves very little air. But, again, at the price it's worth buying one to test.
Silver-Fox
9,287
29,287
Cheltenham Spa
Rapido
im a not so newbie
Try finding a fan of the same spec/size/shape etc. I can't.
It would need some 3D printing doing to design and develop a new shroud/mount/adapter and it still has to fit in that limited space.
Is there one on general sale that is a bit smaller or same od as the genuine one?
If so you could make a holder out of modelling plastic or similar.
Or even fibreglass.
I don’t know enough about 3d printers to comment.
Feb 27, 2011
14,801
76,466
UK
Self Build
Looks like an 60-80mm fan to me.
But size isn't everything. Although swept area makes a big difference you can make up for smaller swept area by increasing rpm it is not linear though.
That tiny little fan you originally linked is unlikely to be able to do the job looking at it. Even cheap computer fans give the specs usually in cfm even if they skip the static pressure.
Feb 27, 2011
14,801
76,466
UK
Self Build
Or even fibreglass.
I have not been able to find one that has suitable specs within those dimensions. I think this may be why SOG chose this one.
Silver-Fox
9,287
29,287
Cheltenham Spa
Rapido
im a not so newbie
What about increasing the size of the tube holding the fan and reducing it back down onto the original pipe?
Would that work?
Terry
11,941
9,134
Lincolnshire
Can't remember ;)
In my DIY efforts I tried 2ins computer fan then 2x2 ins then a 3 and 4ins. 2 ins were not powerful enough. Both others worked good
Feb 27, 2011
14,801
76,466
UK
Self Build
Would that work?
Not likely as it would increase the resistance that the fan was expecting reducing it's performance.
A fan blade is designed to move air through a space equal to it's diameter usually.
It is has been a VERY long time since I did this at college so my memory of the principles and theory are vague at best.
But you do not want to restrict the flow.
