remove bike rack mounting rails? (1 Viewer)
Jan 2, 2023
5
6
Knaus Boxstar ST XL
Hello,
My camper came with a bike rack installed (Thule Elite Van XT - Black - 302013), which I would like to remove. I asked Thule about removing the mounting rails and they said it's not possible once they are installed (as they are glued on). I found some contradictory information online, so I was wondering if someone here has actually managed to remove these rails?
Thank you
brynric
734
1,572
Worcestershire
Pilote G600
I just remove the rack when necessary. To remove the fittings (rails) would leave holes that need filling. Caps can hide the fitting points.
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
We had the same on our van, it had double sided tape and two bolts at the top and the bottom are just clamps on the door, we was going to have the holes repaired and painted, but we couldn't get it done quick enough, so I filled the holes and put reflectors on the doors, 😁 that was 6 years ago 😉 not bad for a temporary fix that was going to be done when we got back from our 6 month trip. 😯😎 Bob.
14,839
76,805
UK
Self Build
Jim fitted ones to his van, I seem to recall it was glued on? Not getting them off in a hurry.
S
Jan 2, 2023
5
6
Knaus Boxstar ST XL
The fittings are not drilled into the door, they are only glued on and secured at each end with a latch, so no holes to fill.
S
Jan 2, 2023
5
6
Knaus Boxstar ST XL
I used guitar string attached to handles at each end to act as a "saw" and I managed to get one of the rails off but in the process I ran out of guitar string! It took about a half hour. When it stops raining I'm going to try again with fishing line to see if that works just as well.
Only problem is of course now there's a bunch of glue left behind on the door that needs to be cleaned up. In retrospect I should have left these on (like someone already mentioned, a good selling point), but I listed the rack for sale online and it sold before I realized what kind of shit show I was getting myself into :swear:
105
123
Scotland, UK
Auto-trail
Leave well alone.
Unbolt the rack and leave the end fittings in place. Assuming there is a rubber type groove cover, aesthetically you could replace with a complete piece.
Keep the bits.
Nanniemate
6,248
43,814
Wales
IH
See ,this is where the ITV here becomes nonsensical.I had to remove all my rear red reflectors years ago as only allowed on commercials.I had to re¡move the white reflectors on the mirror backs at the ITV the other day for same reason.
What has a TV channel got to do with your reflectors :unsure:
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
😜 Richard reading our local newspaper I think you need to give them a back hander at your testing station 😁 whereas ours you can't get a appointment. 😂 Bob.
