Rear suspension (1 Viewer)
Poppy Williams
Poppy Williams
48
11
We have only bought it a few weeks ago. It doesn’t have leaf springs, it only has a single shock absorber mounted diagnolly. I guess I mean air suspension as we want to prevent grounding by adjust the suspension and make the ride more smoother.
Jan 28, 2008
10,131
18,412
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
We have only bought it a few weeks ago. It doesn’t have leaf springs, it only has a single shock absorber mounted diagnolly. I guess I mean air suspension as we want to prevent grounding by adjust the suspension and make the ride more smoother.[/QUO
it sounds like you have an alko chassis the springs are tranverse inside the axle http://www.as-airsuspension.co.uk/alko.html
Jul 29, 2013
9,076
18,651
Salisbury
Hymer B678DL A class
since 2011
Sounds like you have an Alko chassis with rear independent suspension? We fitted VB air assist to the rear of our Exsis 698 when we had it . Made a big difference to ride it is more expensive on Alko chassis though(y)(y)(y)
Jul 29, 2013
9,076
18,651
Salisbury
since 2011
Who fitted this for you?
Had it done by Courtside conversions in Tiverton Devon but there are lots of people that do them I’m sure someone will give you somewhere closer to you than that.(y)(y)
Although we don’t know where you hail from?
Sep 28, 2015
2,031
2,632
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
Ok thank you, we will get and do some research :)
Check out AS Air Suspension of Warrington, they fitted air to the rear of ours and it has made good difference to the ride. We’ve used it a few times to raise the rear when more clearance was needed.
