- Dec 17, 2019
- 1,033
- 1,835
- Carthago Malibu
- Converted caravanner!
Remoska has a fixed output element so yes 400 watts is not a lot but remember that is on continuously, I have a feeling that an air fryer will control the heat by turning down the power consumed so 1000 watts may just be the start up to get it all up to temperature, we don't have one though so not 100% sure, we do have a remoska thoughAn ex Pat on an Aire gave us his surplus small 1,000w air fryer a couple of days ago but it’s got a 2 pin plug so can’t try it out yet. However seen a couple of Remoska recommendations recently and didn’t realise the small one only used 400w which seemed impressive considering AF’s are meant to be the new go to energy saving tech.
The Remoskas tend to need longer as well, can be an hour for dinner.An ex Pat on an Aire gave us his surplus small 1,000w air fryer a couple of days ago but it’s got a 2 pin plug so can’t try it out yet. However seen a couple of Remoska recommendations recently and didn’t realise the small one only used 400w which seemed impressive considering AF’s are meant to be the new go to energy saving tech.
I don't like the end result of food 'cooked' in a microwaveThey did a test on TV recently and found that microwaves were the 34% more energy efficient.
I have a cheap combi microwave at home and find I can cook most things without the additional outlay of an Air fryer.
Neither do I, that's why I use a combi that not only microwaves but grills at the same time, it makes a baked potato taste like a baked potato just faster.I don't like the end result of food 'cooked' in a microwave
If you say so.Neither do I, that's why I use a combi that not only microwaves but grills at the same time, it makes a baked potato taste like a baked potato just faster.
It does similar to other dishes to.
Result, only took 10 minutes for them to go crispy and didn’t blow up or anything! Did notice it kicks a bit of heat out the back vent, so would be careful where you put it?Managed to get a travel plug in Super U today so will experiment with some potato croquettes. Need to be sure it works and he didn’t just offload his broken air fryer on me!
Me too.I don't like the end result of food 'cooked' in a microwave
That's a good point I hadn't considered. We've had a Remoska for years, in fact 2 now so one is kept in the van and the other in the kitchen at home.Remoska has a fixed output element so yes 400 watts is not a lot but remember that is on continuously, I have a feeling that an air fryer will control the heat by turning down the power consumed so 1000 watts may just be the start up to get it all up to temperature, we don't have one though so not 100% sure, we do have a remoska though
We have both and have to say the Air Fryer is far more versatile and quicker, last night we did Potato Dauphinoise so easy in the Air Fryer, would have taken twice as long in the Remoska.Its a Remoska for me it has far more uses.
Just downsized to van and air fryer fits a treat just a small one good for two. Cannot comment on remorseka enjoyWe’re limited to space as we have a PVC, so what’s the best if you had to choose? Currently have 2 gas rings which have served us well.
We only have a 2 burner hob. No grill or oven either in this van. Hence the Remoska.Never found a need for either ..
I do all the cooking on the 4 ring gas cooker, with grill and oven.. and in fine weather on a Weber Q barbie..
Nothing against them, but with space at a premium in a PVC and rarely on EHU they would be a waste of space, and money for us.
We don't have any other 240v appliances .. not even a kettle
Call me old-school, but that's the way we have been doing it since forever..
that makes sense..We only have a 2 burner hob. No grill or oven either in this van. Hence the Remoska.
We don't carry an electric kettle either.
