Pilote Explorateur Maxi Chassis. Where are the Alko Leg Support holes? (1 Viewer)
Emmit
8,043
17,780
Cornwall
Pilote Explorateur
Jan.2014
I fitted Alko drop down supports to the Burstner Aviano A Class.
I found that the chassis had two holes apparently specifically for the purpose
just behind the rear axle. These worked well.
I now have a Pilote Explorateur and would like to fit the supports which I took off before sale.
The Burstner was 2011 and the Pilote is only 6mths younger.
Thing is, I cannot find the holes in the chassis?
Is there anyone out there who has fitted the Alko supports and, if so, did you find the holes, (and where are they?) or did you have the two holes drilled to accommodate them.?
Emmit
Emmit
8,043
17,780
Cornwall
Pilote Explorateur
Jan.2014
I have found the holes.
They were located much further back on the chassis extention quite close to the rear of the van.
The only downside, and downsides for this new to me van have been very few, and extremely far apart, are that the operating arm is above, in terms of height, from the ground as opposed to the side skirt of the vehicle and, as a result, I will have to employ a ratchet socket rather than a long winder.
Well see.
