My new 2021 Dethleffs has previous model headlights (1 Viewer)
Lucky
Lucky
532
1,055
Limousin France & Yorkshire UK
Sunlight Cliff 600XV
Since 2016
The manufacturer could have stock piled the base unit/chassis and only built the motorhome part onto the base/chassis in 2021.
Just out of interest, what date is in the tyres?
I hope you get the answers you’re looking for. Good luck
That's a thought but these are 2014-18 model lights on a 2021 base chassis which is verified by the tyre date stamps.
All I really want is what I paid for. Thanks for your kind wishes.
Grummyb
714
2,205
Corby
Since about 2013
Or a 2014-2018 base model with 2021 tyres on?
May 14, 2021
1,740
2,784
East Yorkshire, UK
ADRIA Twin 640SLB
Since 2012
Our new 2022 Model Adria is being supplied with halogen lights and running lights as the chips for the LED fittings are in global shortage. So likely it is the same with yours.
I suppose the only other option would have been for them to delay building new vans until the chips are back in supply, but that could have been a long wait.
What Phil says will be the correct answer here Lucky. My dealer has received such a van a few months ago & our info is Fiat cannot get the LED lights so are fitting halogen ones and also cannot get the LED running lights so are fitting halogen ones. I’m guessing where the LED running lights should be there is just a blank strip & somewhere else there will be halogen running bulbs fitted, which I think go out when the headlights are put on.
i believe France does not, or did not, have a legal requirement for running lights unlike the UK but that will change soon for new vehicles
Oct 26, 2014
1,887
3,225
Dumfries and Galloway
Pilote P696GJ
Interesting, although mine is advertised as being fitted with them so I will ask.
Can't say I'm terribly optimistic of a positive outcome. I'll update when I know.
I’ve noticed some Dethleff's and Sunlights have have ordinary filament DRL’s and others have LED type
I think it depends on the spec .
BTW if you only have filament type it is possible to fit a single W21 LED replacement
Don’t buy them of eBay as you’ll get error messages
This company supply decent canbus compatible
www.autobulbsdirect.co.uk
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
Since 2012
Pretty sure that LED's are an option on the headlight units on Ducato's, certainly some "freshly" delivered Laika's at our MH dealer had both versions recently in stock.
Lenny HB
53,616
150,687
On the coast in West Sussex
Hymer B678 DL
Traction Plus & Hill descent have been available since 2016 (traction control since 2006).
Check your Certificates of Conformity the Fiat one will have the chassis build date and the Dethleffs one the conversion date.
Dec 2, 2019
4,118
9,241
South Lincolnshire
Rapido 7065+
Broken most bits now
Probably also got and old skool speedo cable aswell, Volvo are certainly having to do this due to semi-conductor shortage
jako999
304
785
Halesowen
Niesmann Bischoff
LEDs look much better but wait till they go wrong a bulb costs a couple of pounds where as it’s a unit replacement costing hundreds, I lost a bank of 4 leds out of about 50 on the tail light of my Lotus a replacement unit was £360 a friend was quoted nearly £2000 for a replacement headlamp on his car. My wife’s car has these full matrix head lamps they are amazing splitting the beam, cornering and dancing all over the place but at what cost.
1,316
752
Norwich
Carthago A class
Since 2014
Im not sure if you can replace halogen with LED as a straight swap. The ECU measures the current and will probably say bulb not there as expecting higher current draw from a halogen. Another member on here had similar issue with a Carthago not arriving with LED drls.
Lenny HB
53,616
150,687
Hymer B678 DL
Just remembered, if the DRL are different to what the ECU has been set up for a warning light shows on the dash and its not reprogramable, so it's not possible to change them.
Feb 16, 2013
19,760
52,151
uttoxeter
ambulance conversion
50 years
Don't think the op was so much worried about which bulbs were in but more about the age of the vehicle.
MichaelT
3,065
5,600
Colchester
Dethleffs Esprit I7150 EB
Since 2016
Looking at the Sunlight website configurator looks like LED lights (as well as HDC & Traction Control) are an optional extra.
Apr 12, 2010
4,817
51,995
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
After a tyre blow on the A1 returning from Lincoln I just had 2 new Davanti DX 440 tyres fitted. The date stamp was 8/21 (week 8 2021) so things are never right up to date.
Phil
Aug 26, 2008
4,771
25,063
B&NES
Van Conversion
since 2007
Mine is December 2016 build and the Traction Plus and Hill Descent were included as standard but I had to order the DRLs as an option.
What you get as standard is very haphazard, it seems. It could depend on what Spec the particular converter ordered in advance.
