Maaxfan lid. (1 Viewer)
Jan 18, 2019
541
916
Cuesta Blanca, Murcia, Spain
Hymer Exis
Since 2010
Well pleased with the unit fitted yesterday, a really neat installation.
BUT, due to a spanglais issue (I presume) I've got the transparent lid whereas I wanted the translucent one.
Anyone with same stuck anything on the OUTSIDE of a transparent lid to reduce light transmission? If so, what ? Did it last ?
Fablon ??
funflair
19,414
30,516
Guisborough
MORELO palace
since 2012
Stops ventilation !!
Not completely as it has little ventilation holes, I know what you mean about the clear lid though as we had one fitted yesterday and I think translucent would be better.
Nov 13, 2011
1,483
3,529
Lincolnshire
PVC
30 years
Halfords do bumper paint in spray cans. It is designed to go straight onto plastic. They do two shades: light or dark grey. I have used it a few times with excellent results.
Geoff
Minxy
32,689
66,703
E Yorks
Carthago Compactline
Nigel Crompton
Jan 18, 2019
541
916
Hymer Exis
Since 2010
You can get external film, example below:
These films are electrostatic, no adhesive. 100kph winds ... ??
Oct 24, 2020
571
2,382
VW
Since 2017
Greg Virgoe has a great Youtube channel about building vans. He has at least a couple specifically about maxfans, one showing all three different lid colours and their effect on light.
Maxfan lids
Clear = transparent
Smoked = almost the same as clear
White = Solid white but allows light around the edges so not really totally black out
You can but the roller blind cover (with/without lighting) or you can make a simple pad to pop in the hole, or buy a seat cushion from IKEA that does the same for about Ā£8
Nigel Crompton
Jan 18, 2019
541
916
Hymer Exis
Since 2010
No !!!
did you not read the information in the link >>?
  • Will not interfere with the normal operation of the rooflight or powered ventilation Maxxfan.
Yes, I did. I chose not to believe it. If you have an unobstructed 40x40cm aperture for the free flow of air and then fill that aperture with a baffle how is that not going to affect throughput ?
Nigel Crompton
Jan 18, 2019
541
916
Hymer Exis
Since 2010
It was just an example, probably something 'sticky' on Ebay! šŸ˜„
There are several products available on amazon.es, but here in Spain anything I use has to be UV stabilised with glue that doesn't melt in t'sun. I'm looking for leved experience here, really ....
Apr 3, 2018
3,687
10,267
PVC
1995-2004 & 2017怋
You said it STOPS ventilation
It doesnā€™t stop it !!
Might not stop it. But it must severely reduce it...
Impossible to get anywhere near as much of a flow thru those pinholes as apposed to a gaping 400Ɨ400 hole in roof..
Apr 3, 2018
3,687
10,267
PVC
1995-2004 & 2017怋
Struggling to follow this thread until I noticed #3, #13 and #16 has disapeered!!
May 31, 2015
11,726
44,675
Cornwall
Ducato PVC
Getting Better
Maxfan lids
Clear = transparent
I can concur with that, I have the smoked vent and from the inside it just looks clearā€¦.
Minxy
32,689
66,703
E Yorks
Lived? Other thing I thought of was to make a panel to fit on the underside of the acrylic which due to the curve you should be able to make a tight fit and the 'bend' should ensure it stays put even if you are travelling with it in use ...
Nigel Crompton
Jan 18, 2019
541
916
Hymer Exis
Since 2010
Discovered that Maaxfan make black cowls that cover the whole thing. But once stuck on the roof the fan becomes completely inaccessible ... dunno yet whether they're available in eu
Feb 19, 2018
4,945
85,541
EAST ANGLIA
Murvi Morello
Since 1975
What about a big Fun sign so that when Jim is flying over in his helicopter, he can spot you and drop food parcels etc. šŸ˜„
