OK thanks, I sort of knew about the rotation of the tank in it's mounts but this one looked OK from what I could see (maybe Basildog has adjusted dit already) so wondered if there was something about it should run North South but I couldn't think why.Depending on the direction of rotation from the correct position it will cause under- or over-filling of the tank.
Good point about the exhaust but there seems to be a baffle plate between the two, we will have to wait for teacher to come back from his breakIs this a test?
So, to my uninformed eye, the gas inlet is near the fridge vents which creates an obvious spark danger.
And the tank is right next to an exhaust which will run hot. And may also also need a 90 degree reorientation.
Pass/fail/must try harder?
It should be mounted at 105° , so as said the dip tubes won’t be at the correct orientation at the top in the vapour sector , also the fill stop valve will either underfill or overfill, @ 90° it’s going to underfill .OK thanks, I sort of knew about the rotation of the tank in it's mounts but this one looked OK from what I could see (maybe Basildog has adjusted dit already) so wondered if there was something about it should run North South but I couldn't think why.
3 way so a naked flame just behind the ventilation grillCompressor fridge!? Just blank off the grills - job done!!!
Did you fill it up at yours or send them to morrisons3 way so a naked flame just behind the ventilation grill
It might sound unbelievable but we really do get customers that have their fridge running on gas when they pull up to fill with LPG.Did you fill it up at yours or send them to morrisons
I had one say “ It’s never been a problem before “
