Is 6amps enough (2 Viewers)
Jul 10, 2019
29
20
Carado Low Profile
Since 2016 caravan previously
Just looking at booking some sites through ACSI. Will 6amps be enough on a pitch in June?
Dec 24, 2014
9,274
47,847
Hurstpierpoint. Mid Sussex.
Compass Navigator
Probably but it depends upon what mains powered devices you will be using (the one's you'll have on or that you will switch on at the same time).
Reactions: f6c
Jun 14, 2014
1,463
3,144
Coventry
IH N680CFL
Since2014
Camping car parks only have 6amp and we run our air conditioner no problem. Along with fridge and charger.
So yes it is ok. If we boil a kettle we turn off the air conditioning.
Jan 6, 2024
105
282
Cheshire, UK
AS Warwick XL MQ
Since 1986
Do what Fragle says. Know the wattage of all your devices and make sure you don't exceed 1300 watts.
Most sites have accessible MCB's now, so if you are unlucky you will probably be able to reset the breaker.
Regards,
Mar 26, 2009
8,173
11,255
Yr Wyddgrug
Hymer B678DL
Most campingcarpark aires I've used don't have user resettable trip switches. You have to call them and they engage a local electrician to come and reset it. The boxes are locked.
Oct 7, 2013
5,912
37,066
South Wales
Swift Escape Compact
Since 1988
Check the power requirement of each appliance, don’t forget the water heater etc.
Remember
Amps = Watts divided by volts
A rough calculation will give you a guide.
2000W kettle divide by 250Volts, (near enough approximation to keep maths simple) = 8 amps
1000W kettle or water heater / 250 volts = 4 amps
We carry a low wattage kettle and normally use CCP Aires which have 6amp supply. Pull up, boil kettle, when it switches off switch on water heater etc keeping the combined load below 6amps.
Our motorhome has the facility to limit the total load in order to avoid tripping the site supply by setting the limit on the control panel.
Sep 10, 2013
1,187
18,750
Chelmsford Essex
Getting better
Watch your domestic water heater, I forgot mine was on in the background and we popped the 6amp breaker, had to report to the office and receive a reprimand in French as to the profligate habits of British holiday makers not understanding the value of French electricity, or I think that is what he said as he walked to our pitch to reset the breaker for the second time.! Lesson learnt..until the next time ....
Apr 3, 2018
3,719
10,301
1995-2004 & 2017》
When we first started out ( as tuggers) I instilled in Mrs Poppycamper the need to always but always turn everything off ( even if on 16A ). Before firing up her hair dryer..
She never understood if we on 6/10 or 16 A. So got in habit of turning everything off regardless..👍👍👍
176
296
Autotrail
Find 6amp fine to run fridge, heat water on EL1 power mode, charge batteries and use a 1000w kettle, even a USB to charge phones in the van. Anything else above that can cause trips.
Clive Mott
Nov 12, 2012
284
468
New Milton
Concorde Charisma
Ditch the wifes electric hair dryer and aircon when the low wattage kettle is on. Set your electric water heating to 1kw but turn it off when boiling kettle or want aircon.
Mar 11, 2013
1,284
1,691
Gillingham
since 2005
If you invest in something like this you could perhaps put in line with you hook up cable and make a note of each item you will use before you set off. Eg fridge, water heater, hot plate etc.
meanders
Funster - Life Member
2,674
8,687
Ipswich, Suffolk
As said above avoid anything that heats or has a large electric motor. So kettles and toasters are generally out. (Most domestic kettles are 2.8 or 3KW so will draw 12-13 amps) Use a gas kettle. (we don't even carry an electric one now.) as mentioned hair driers, tongs, irons, fan heaters, even domestic vacuum cleaners etc should all be left at home, albeit the fairer sex may object to the former. Loads of threads on here about this issue. To repeat the key message, there is no such thing as a 12v hair drier! Towels, wind and sunshine come power free.
Remember you are camping with 6A available, not at home with perhaps 80 or 100A available.
Apr 28, 2022
338
633
Western France
Pilote G600
The reason the French get ratty is because, even at home, they have restrictions on power consumption. It is common to have a 12kw limit on your supply. We have 18kw because we use storage heaters but our standing charges are higher because of that. My electrician gawked when I described a UK ringmain circuit!
Aug 16, 2018
294
2,899
Wilmslow
Coach blt, Swift KTS
Since 2016
Most of the ones I've used do
Jun 5, 2020
505
1,142
New Forest, United Kingdom
Hymer Exsis-I 414
4 years, travelling to Greece each year and exploring on the way and back
Not strictly true... Have tripped out the one in Luneville and was able to reset the trip.
Oct 25, 2016
5,587
31,666
Hartford Cheshire
Bailey Autograph 79-
Lots but slow learner.
On a site now that we have paid a bit extra to get 16amps as we need the stand alone heater, the van heater, the micro wave, the electric kettle and electric hob for cooking. The trip in the box is accessible should it trip :giggle: (y)
