In France with nothing holding bonnet down. (1 Viewer)
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
We are not having a good day. We are on the Tunnel in the morning. Just lifted the bonnet to find that there is nothing holding it down. The 'pin' in the bonnet itself isn't there. It looks like it should be a threaded bolt, probably with a spring on it.
There is another Brit on the site, we asked if we could look at his Merc to check what it looks like. His wife wouldn't let him help us. We have tied the bonnet down with an elastic strap. We have to catch The Shuttle as Jacques only has until tomorrow afternoon time wise for his worming. We have never left it this tight before. We thought that we could pull in at the petrol station as you exit the tunnel in UK and get Mercedes breakdown out.. I'm not sure if it's a Mercedes part or not. If not I'm not sure what happens.if it's a Carthago bit.
Himself says that with some rope he could probably rope it down, not sure what damage he will do.
It's not really broken down, but it's not safe on a motorway.
I dare not drive 250 miles with a bit of elastic holding the bonnet down.
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Can't send pictures it's all tied up ready for the morning. It doesn't have a second catch, it's an A Class if that makes a difference.
If it wasn't for the dog we would find a Brico store and sort some rope.
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
You may well find that it has become unscrewed and is under the hole in the slam panel, in front of your radiator
That's where we looked, it has a hidden bit that we can't get at. If we make it under the Channel
Ok we will take the bottom panel off at Folkestone and have a look.. I've been on my hands and knees searching the grass, but I can't see how it could come off when I lifted the bonnet without me noticing.
Hi ho isn't life interesting.
Apr 15, 2015
620
1,089
Whitchurch, Shropshire
Carthago E-Line 50
Since May 2011
Sounds like it’s an A class Carthago on a Mercedes chassis. Mine’s an E Line but I’d guess they’re all the same. I’ve attached a couple of photos of what should be there.
Tombola
4,923
16,016
Merseyside
Rapido 8094DF
You'll be fine with it tied down certainly on the tunnel.
Get to Folkestone secure it as good as poss and just do 56 home.
Or call out the emergency services when back in the uk
Apr 15, 2015
620
1,089
Carthago E-Line 50
Since May 2011
There’s probably a scuttle under the engine (there is on mine). I dropped my phone down there once and had to fish it out from underneath. If the pin is missing from the bonnet, it may be worth looking in the scuttle to see if it’s ended up in there.
Given the angle of the bonnet, I can’t see it coming open if it’s cable tied to something.
Best of luck getting it sorted.
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Thanks all, we are due at the Tunnel early, hope it doesn't rain as at the moment the bonnet is tied down utilising the wipers as a solid point. I'll stop panicking once we are through the dog check in.
Apr 15, 2015
620
1,089
Carthago E-Line 50
Since May 2011
Is it just the pin with the spring that’s missing, or the whole plate? May be able to get a pin that threads into the plate if the plate is still there.
Sep 21, 2016
3,819
14,496
DERBYSHIRE
Frankia i740
since 2007
I wonder what was up with the miserable pair who wouldn't help you by letting you look under their bonnet. Still, what goes around comes around.
It was the wife who wouldn't help, maybe she thought it was a scam or robbery attempt. I panic at stuff like that.
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Plate is still there, hopefully when we unscrew the scuttle it could be there.
Jan 11, 2022
611
583
Pilote P732 2011
3rd Time around, since 2000
Something like this
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
We are on a site at Escalles not an Aire, she said he needed his rest as he'd had a long drive. It's the only other Merc on the site.
May 7, 2016
7,360
11,919
West Sussex
Malibu Van 640 LE K
Since 2003
An A Class bonnet is probably a Carthago matter not a Mercedes one. I have a couple of picture of my Carthago A Class bonnet but it is on a Fiat not a Mercedes. It does have a secondary release but they both rely on the same bit attached to the bonnet.
Bonnet side.
Vehicle side.
Hope this is some help.
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Dec 24, 2014
9,318
48,085
Hurstpierpoint. Mid Sussex.
Compass Navigator
Instead of to the the wipers, can you not contrive away to secure one end of the tie-down strap at/through the bracket with the missing part that's inside the bonnet?
Casper46
May 4, 2015
1,245
1,646
North Yorkshire
since 2000
Bonnet side.
Vehicle side.
Everything helps, if only to rule out that it's nothing like that. Still a big thank you.
Sep 21, 2016
3,819
14,496
DERBYSHIRE
Frankia i740
since 2007
Aye you're probably right, but on a campsite in daylight and outside the van shouldn't feel too threatening.
Sorry, but I would still feel it was a scam. I watch too many don't get scammed shows:giggle:
